Hello all,
I encounter an issue when using a Custom fields with Wiki Style Renderer.
I have a custom field "Last comment" define with the following SIL Script :
string[] lastCommentDetails = getLastComment(key);
if(!isNull(lastCommentDetails)){
return lastCommentDetails["text"];
return "";
In the field configuration of my project, for this custom field, I select as Renderer "Wiki Style Renderer".
Then I create a filter and watch the column "Last comment". I get this :
The column displays correctly my custom field "Last comment" with Wiki Renderer Style.
But when I create a Confluence page and call for my filter (and select the column "Last comment" in display options), I get the following result :
I would like to have on my Confluence page the same display as in my filter in Jira.
Do you have any idea why I have this issue and how can I resolve it?
Thank you,
Maria Yacoub
Still an issue.
Confluence version: 8.5.18
Jira version: 9.12.15
In Jira all is rendered fine. In Confluence it is just a long text without any word wrap or formatting.
Same problem here.
This post dates back from 2020... Anyone found a solution ?
