Do Jira Data center Support Redundant LDAP
prudhvi raj August 23, 2018
Is there any possibility to configure redundant LDAP system in Jira data center.
As I have multiple LDAP with different set of users
Daniel Eads
August 31, 2018
Hi Prudhvi,
Jira doesn't have native failover support for multiple domain controllers / LDAP servers on the same domain. We've got an open feature request for it here. You can work around this on the LDAP side by configuring your servers in a High-Availability configuration where a load balancer redirects traffic from one LDAP server to another if it detects connectivity issues.
As for configuring multiple domains, yes - Jira supports multiple user directories. You can read up on using them here. You can configure this to use separate LDAP directories either on the same or multiple LDAP servers where the organizational unit or domain are different from the user directories you've already added to Jira. Since you mentioned different sets of users, I believe this is what you would like to do.
Daniel
prudhvi raj September 12, 2018
Thanks for the information Daniel
Matt Doar
Daniel, it's my understanding that load-balanced LDAP servers don't work with Jira either, or at least that incremental syncs fail. May have changed?
Daniel Eads
June 24, 2019
Hey @Matt Doar - you are correct, we don't actually officially support/recommend load-balanced LDAP still. Bad assumption on my end!
Official references that Jira still should not be using load-balanced LDAP:
