Hi, I have been following Jira-GitLab Integration but according to 4th step i am not able to find the "Grant JIRA Core access to group", Is JIRA Core different from the standard JIRA application? do i need a plugin to enable that option? i am not able to find this option on my JIRA application, Below is the version details of the JIRA application i am using.
- Bug tracking and project tracking for software development powered by Atlassian JIRA (v6.2#6252-sha1:aa34325)
Hi Frederic, Can you please answer my first question, Is JIRA Core different from the standard JIRA application?
Hi Vineet,
Yes there are differences, check https://confluence.atlassian.com/migration/jira-7/cloud_jira+agile_product-changes
F.
I am sorry i asked the wrong question, i was about to ask, If my server is JIRA (software) not JIRA core, will GitLAB integration work on my server without any plugin.
I know this is too much to ask, but i need to show it to my mangers as it is a paid plugin.
If I'm not wrong, JIRA core can not integrate with Gitlab (JIRA Sofware can integrate with Bitbucket, Github, but not Gitlab). Hence why we are using the Git integration plugin on our side.
Hi Fredric, Can you please check this quote from GitLAb doc.
Hi Vineet,
Well looks like Gitlab integration with JIRA Core is possible without any plugin. But, looking at the prerequisite configurations, especially on Gitlab side on a per project basis, this can be painfull to do if you have a large number of projects to configure for integration with JIRA.
Anyway I did not try what's described on Gitlab page for JIRA Core...
Read the story
