Do we have an option to run effectors automatically?
Babith C_J_ September 11, 2022
I need to run effectors when there is a change in calculated value in a formula field. Do we have any configuration to achieve this ? or else is there a workaround?
Could you provide the steps to do this in on-prem JIRA version?
YogeshKR
September 12, 2022
Hi @Babith C_J_ ,
A month back , i too was looking for the same and got a solution !
And Yes! we can achieve it with the help of ScriptRunner Jobs by scheduling it. Please refer the below ALMWorks Wiki and link for more details,
Run all effectors by schedule (almworks.com)
Solved: Structure Effectors - automatic run (atlassian.com)
Hope this helps you !
Yogesh
Babith C_J_ September 12, 2022
Thanks @YogeshKR .I had seen this suggestion while searching on this topic but yet to try as am not familiar with ScriptRunner. Will try it. Can this be used to automatically update fields when there is a change in calculated formula value in a structure?so that it immediately reflect values "On change" than waiting for a schedule to run? Thanks for your suggestion.
Like Dave Rosenlund _Trundl_ likes this
