×Hello,
i am looking for a way to comment workflows.
I am thinking of a artifact that you can add as Condition, Validator, Post Function etc.
All it does is you get a multi line text field where you can put explanations about other things that you put in the workflow.
The idea is to be able to add textual content to a workflow to have an inline documentation that explains things that woud otherwise be hard to understand when looking at the workflow.
Did someone already build a plugin for this?
Cheers
Jens
Dear @Jens Kisters //SeibertSolutions
With Smart Project Config and Documentation you can generate the documentation of your workflows in seconds and publish it to Confluence. In Confluence you can add textual content as needed.
Hope this helps
In the meantime im trying to document it like this (using a multi line Text field and JWT)
