Does JIRA Toolkit Plugin 0.35.9 break issue details view on JIRA 6.2.7?
Danny Hendargo July 30, 2014
On JIRA 6.2.7, JIRA Toolkit Plugin version 0.35.9 seems to block the issue view on the Issue Navigator's Detail View.
* If I disable the plugin, issue details are displayed.
* If plugin is enabled, issue details are not displayed. From top to bottom, only issue key, summary, and buttons are displayed.
Does anyone else see / have this issue? Any fix or workaround?
Related to this, how do you default the View to "List View" and either disable the "Detail View" option or remove the Views dropdown?
Benito Picarelli
August 24, 2014
Hi Danny,
The only issue regarding this plugin was that in version 0.35.10 it seemed to block notifications from going through but I'm still investigating this. I'll update with my findings when I get more information.
Let's build A Rovo Agent 🤖
Save your spot
