I have a project contain several theme such as "Standard - A", "Standard - B", "Standard - C" and could be extend to X. wondering if I can filter them all with a wildcard instead of manual add one by one? thanks in advance
Hi @Cheng Zhi Jie ,
welcome to the Atlassian community!
Please could you try the following JQL :
Theme ~ 'Standard -'
Hope this helps,
Fabio
Thanks @Fabio Racobaldo _Herzum_ for your reply. I have tried but got below error. seems it does not support ~ for Theme field.
The operator '~' is not supported by the 'Theme' field.
Hi @Cheng Zhi Jie ,
The theme here refers to many classes of IssueType or some description of issues summary?
Hi @Cheng Zhi Jie ,
Please confirm the type of this field with system administrator to determine which JQL syntax can be used.
