From my understanding of this issue, https://bitbucket.org/pigsty/usetfs/issue/70/bidirectional-sync-of-stories-and-tasks, UseTFS does not sync issues both ways. Can someone confirm this for me? And - if anyone can provide a positive/negative reference, I would appreciate it :)
It synchronizes both ways.
I can provide positive feedback but not sure if it counts since I work for Pigsty ;)
No, I'm worried you're not objective enough :)
Well, I'm doing my best to be objective enough. I'm not a salesman ;)
I can tell you honestly that proper configuration of UseTFS can be really painfull especially for tricky scenarios. On the other hand it's usually possible to cover really twisted cases - which may not be the case with other plugins.
Anyway feel free to ask in case you don't get responses that you're looking for.
I do not believe this case is a tricky one. We use the standard issues with some additional statuses. It will first and foremost be synced with one project collection in TFS.
