We currently use Jira ticketing system in our organization, and we are now planning to use Jira Insight as our Asset Management system. The main sticking point is that Insight doesn't have a built in Reporting system or a Dashboard where we can look up information. It is not feasible for all users to run IQL queries.
Has anyone configured a reporting system using built-in feature in Insight, or used an addon to get this done? If so, a few screenshots would be highly appreciated!!
Hi @promod.mathew ,
at the moment there are no reporting capabilities built-in for Insight. You can have a look at this comparison table for Cloud and DataCenter features : https://support.atlassian.com/jira-service-management-cloud/docs/what-are-the-differences-between-insight-in-cloud-and-server/
You will have to use a third party app, like EazyBI for example.
Let me know if this helps,
--Alexis
Hi Mathew,
in case you want to use all the default Jira reporting features for your assets you could consider an issue based asset management approach as it is done by this app. Feel free to write me for questions to bfrauen@stagil.com. :-)
Best regards
Björn
