Does the Audit Log Capture Deleting a Roadmap?
Steven Janvrin
Does the audit log capture deleting a roadmap/plan?
3 accepted
Joseph Chung Yin
@Steven Janvrin -
It is my understanding that when a AR plan is deleted, there is no logging captured in the audit log.
Best, Joseph Chung Yin
Jira/JSM Functional Lead, Global Technology Applications Team
Viasat Inc.
Steven Janvrin
Thanks Joseph - this does seem to be the case.
Laurie Sciutti
Hi @Steven Janvrin ~ I don't believe so but you may be able to change logging levels.  Maybe reach out to Support for guidance?  I have not been able to find this information in previous searches for on-prem instances though it appears to be available for Cloud.
Steven Janvrin
Thanks Laurie - appreciate the feedback.
Dan Breyen
Hi Steven, I found this document from Atlassian regarding audit-activities-in-jira-applications. .  There's a reference to "your plan changes" but nothing specific to Roadmaps.
Hope that helps.
Steven Janvrin
Thanks Dan - appreciate the guidance.
Learn more
