Hi Team,
If I change my domain administrator password, users are unable to login to JIRA URL. After resetting to old password, again it started working. I am assuming the domain administrator password is bound in JIRA installation files or in a configuration file. I would like to change this binding with another user account instead of domain administrator. Could you please help me with this?
Please note that we have configured LDAP authentication and configured with dedicated separate ID, not the domain administrator.
D Naveen
JIRA just uses the username and password that you enter when you configure the LDAP directory.
Are you sure?
Are you sure you are changing the domain administrator account and not your "separate account"?
Can it be that changing the domain administrator account also changes the "separate" account???
Note that JIRA LDAP has a test screen where you can type in username and password to check connection and valid settings.
Alternatively Apache has a free LDAP client.
https://directory.apache.org/studio/
You could use it to independently confirm the behaviour of the LDAP server - trying logging in to the two accounts from there before and after the password change.
You are correct Nic, I searched and don’t see any hard-coded entries. I don’t see any errors in LDAP authentication and I don’t see any errors when I ran an LDAP authentication test also. Users are not able to login to the URL, if I reset the password for the domain administrator account, so I revert back it to old password. I have tested same two times.
D Naveen
There's no hard-coded password, or one in a configuration file.
It sounds to me like there is something wrong with your LDAP synchronisation if the password is not coming across. Could you check that LDAP is set up correctly and showing no errors in logs or the UI?
Read the story
