Done do not change the graph, using programmer template created vs resolved
ldrrp
November 5, 2013
Converted my template over, also using other fresh templates for other projects, the chart does not seem to be tracking "Done" as resolved
com.atlassian.jira.gadgets:created-vs-resolved-issues-chart-gadget
Peter Van de Voorde
Hi Luis,
Do you set a resolution for each issue you put in the status done?
If you do not do this then the issue will still be classified as unresolved.
Best regards,
Peter
ldrrp
November 11, 2013
Thanks, it works now. Theres a big spike in my chart haha
Hilla Cohen
April 28, 2020 edited
keep in mind that it affects only on the issues that created only after you set one of the statuses as resolved, meaning it won't affect old issues that are in done
