Our JIRA instance is behind a firewall and does not have access to the Atlassian plugin exchange. Could you please point us in the right direction for downloading the plugin or make it available to us? The plugin links seem to have moved.
Thanks.
Just to add on Fernando answer, you can follow the steps mentioned in the following page to manually install Bonfire plugin in JIRA:
- Installing Add ons by file upload
Cheers
You should be able to download the plugin here: https://marketplace.atlassian.com/plugins/com.atlassian.bonfire.plugin
and then manually upload it to your instance.
Hope this helps.
Cheers!
