Sign up Log in
Download JIRA back up --how?
Swathi S May 15, 2019
Hi All,
   I have two JIRA instances in to different linux servers. My goal is to take back from JIRA on server 1 to JIRA on server 2. I have taken the back up of the JIRA on server 1. But now i m sure how can restore this back up on JIRA server 2. How can i download the back from JIRA server 1?
Is there any easier or better way?
Swathi S
Danyal Iqbal
May 15, 2019
- The backup xml is lying in the export folder in your installation. Copy it to the other machine in the import folder with your favourite tool  e.g winscp if you are on windows  or rsync or cp on linux directly. you can restore this xml backup from the front end on the second server.
Swathi S May 24, 2019
Thank you i was able to download and restore. Since i was using Kubernetes service. I had to search command for kubernetes copy but it worked thank you.
victor.martinez August 22, 2022
a new idea to be able to download directly from JIRA https://jira.atlassian.com/browse/JRASERVER-74216
Andreas
May 15, 2019
Have you tried running JIRA on a virtual machine? This makes it relatively easy to create backups/ snapshots etc.
Virtualizing JIRA (JIRA on VMware)
