Download more than 3000 issues at a time excel file
DeepakBhatia
I have 4700 issues in my project in JIRA.
I am facing two problems
1. When I list all the issues in issue navigator, it displays 1000 issues. But I can download 3000 at a time.
2. When I goto to issue 3001 to 4700, it agains downloads from 1 to 3000.
How can I download all the 4700 issues at a time ?
Deepak Bhatia
parthiban subramaniam
June 14, 2012
Have a look at here and make the necessary modification for your version
https://confluence.atlassian.com/display/JIRAKB/Export+More+Than+1000+Results+to+Excel
DeepakBhatia
Hi Parthis,
I am getting following error
Access to the specified resource (You are not allowed to get a result set of more than 3000 results. Current search returns 4702 results) has been forbidden.
Regards
Deepak Bhatia
June 14, 2012
You need to grant permissions as well like so
jira.search.views.max.unlimited.group = jira-administrators
this should go in a file called jira-config.properties under jira.home
if you dont see a file there create one and add this property
DeepakBhatia
I am updating the jira-config.properties with
jira.search.views.default.max = 6000
jira.search.views.max.limit = 6000
DeepakBhatia
Thanks, you mean if I set
Then only JIRA Administrator will be able to view maximum
DeepakBhatia
My new jira-config file has following values
jira.search.views.max.unlimited.group = jira-users
As we have users who mostly access JIRA from LAN....Please confirm, Thanks....
June 14, 2012
looks good .. dont forget to restart .. a word of caution .. this is not a default for a reason and might affect your performance.. use it with care
Nic Brough -Adaptavist-
June 14, 2012
To echo Parthis' warning - downloads of more than a couple of thousand issues WILL kill your performance if you do them a lot. If it's irregular and only one or two people do it, you'll be fine, but if 30 people all run similar large downloads at 2pm on a Thursday because it's a meeting time, you will find the server grinds to a halt.
It's always worth questioning people doing large downloads - it usually means they need training, help or that they've got a broken business requirement. In some rare cases, they actually need some code to help them.
