I'm trying to download and look at JIRA source for the first time. When I downloaded "6.1-m02 Source (ZIP Archive)" there were seven files whose names were too long for Win7 so I had to skip unzipping them.
Should I use a different file to download to a Win7 64-bit box?
Where are you unzipping them? In the root folder of C:\?
Thanks for the idea Timothy, unzipping them in a folder other than C:\ worked. Do you know why?
It's either your program that you used to unzip or the path is really too long.
I suggest you try Long path tool is the very good program
for easily delete, copy & rename long path files, error,
unlock solution.
Try it and solve your problem.
What program do you use to unzip the file ?
