During Transition seta value to Assignee field by taking from "Change Reviwed By (TL) " custom field
Mridula Umesh May 28, 2024
Hi Team,
Please help me to provide the script in post function for above question
where I need to set the value to the Assignee field taking from the "Change Reviewed By (TL)" Field
during the Pending TL review transition
Jira Version 9.12.1
Thank you,
Mridula U
Charlotte Santos -Appfire-
May 28, 2024
Hi @Mridula Umesh
I’m Charlotte, a support engineer at Appfire and I’m here to help you.
If you’re considering a third-party app, with Jira Misc Workflow Extensions you can add the Copy issue fields (JMWE) post function to the transition you need and by selecting the source field and the destination field, when you transition the issue it will copy the information from the Change Reviewed By (TL) field to the assignee.
Here is an example I did in my instance:
And last but not least, please contact our support if you have any questions about this post function or about the app in general.
We’ll be happy to help you! 😉
Hi @Charlotte Santos -Appfire-
We are not using any third-party apps. Please let me know if the plugin doesn't need a license then will install and configure it as you suggested.
Else Kindly provide another approach for this problem.
Thank you,
Mridula U
Vicente Domínguez [Decadis AG]
May 28, 2024
Hello @Mridula Umesh,
Do you useJira Workflow Toolbox ? If you do, you could update the Assignee field with a value copied from another field with the post function Update or copy field values without the need to script.
By the way, I am part of the Decadis team. If you want to learn more about it, please, feel free to create a request in our Support Portal, to visit our documentation or to reply us in this thread.
Best regards,
Vicente
Hi @Vicente Domínguez [Decadis AG]
Thank you for your prompt reply.
We don't use Jira workflow Toolbox. Please suggest any other solution to fix this issue
Thank you,
Mridula U
May 28, 2024
Hi @Mridula Umesh,
Apologies, another approach does not come to my mind at the moment.
Best regards,
Vicente
atlassian, jira product discovery learning path, product discovery training, idea prioritization, align stakeholders, discovery to delivery, product collaboration, atlassian learning, dev process, roadmap planning, insight capture, team alignment
Elevate Your Skills with Jira Product Discovery!
Unlock your potential and learn how to use Jira Product Discovery to your advantage. You’ll have the expertise to revolutionize ideas and insights, roadmapping, engage and align teams and stakeholders, and deliver the best solutions—faster. Enroll today!
Start Learning
