Sign up Log in
Dynamic Forms with JIRA v6.2.4 - Can not configure Releated Fields
JT
June 3, 2014
I am using Dynamic Forms V1.6 against JIRA v6.2.4. I have added a new Dynamic Select field and added the Options. When I go to the option configuration screen, I do not have the Related Fields option.
Is anyone using this Add-on successfully in JIRA v6.2.4?
Łukasz_Krupa
June 5, 2014
Are there any errors in log files. Could you check also java script errors in web browser (for example in FireBug), please?
I run it on 6.2.4 and works perfectly fine.
JasonT June 5, 2014
I have version 1.6 running on JIRA 6.2.2. Did it stop working after a JIRA upgrade, or had you not installed/worked with it before upgrading to 6.2.4? If it was working before, but not now, I am curious if you still have the option to add a dynamic select box.
JT
June 5, 2014
It stopped working after the upgrade to JIRA v6.2.4. it was working on JIRA v6.1.7
Łukasz_Krupa
June 4, 2014
Please, check if you have intenso-jira-tools plugin enabled. If it was disabled, you may need to disable DynamicForms plugin and enable it againt (it depends on intenso-jira-tools and needs to register its actions on start up).
JT
June 5, 2014
Lukasz,
The intenso-jira-tools is installed. I have tried disabling/re-enabling the plugins. I have also restarted JIRA. I am still not able to configure the Dynamic Fields
