We are using the Standard Mail Handler to receive E-Mails to create Jira-issues.
This works really fine. We got E-Mails and Jira creates the corresponding Issue.
We also need to process the Attachements. Those shall be attached to the Issue.
How to configure Jira that this will work?
I did not find anything in the forum and on the documentation.
Hi @thomas
I hope you are well.
By default, Jira should process the attachments and add them to the created issue.
This is described in Creating issues and comments from email .
Some considerations:
Thiago Masutti
Thank you very much.
This is exactly as we need it to process,
I will investigate now further based on our log-files (as the error seems to be on our side).
You can close the ticket for now and If we would need further Support, I would open another Ticket.
Thank you very much for the great and fast answer
Thomas
Learn more
