When I am querying for issues, (Search screen) I see options under the Status filter. The order of these depends on the order listed under Issues --> Statuses under Administration. Is there another way to control this order, since re-ordering what could be hundreds of Statuses on the Admin screen is not easy to do? I was hoping I could use opsbar property in the workflow, but that does not change the order of the listing under the Statuses filter on the issue Search screen.
Hi Kathy:
Unfortunately, it is not possible to control the ordering of statuses in the search UI out of the box. Within each project, you can control the display ordering within a Workflow, but not in the search UI.
You can look into Atlassian Marketplace for possible third party add-ons that can provide you with the functionality (I am not aware of any at this time). You can also contact Atlassian Support (https://support.atlassian.com) for possible assistance on this matter.
Sorry.
Best, Joseph Chung Yin
Jira/JSM Functional Lead, Global Technology Applications Team
Viasat Inc.
