I have a numeric cell, and I want to format the cell if it's within a range or if it's empty. I can do one or the other, but not both.
If EazyBI would try empty cells as a numeric "0", then range formatting would solve this. Or if an empty range matched empty cells, it would be solved. It doesn't, so I've used a regex of "^$" to match empty cells, but I haven't found a way to use Range and Regex conditions at the same time.
EazyBI version 6.4.2
Found my own answer shortly after posting this question. I used Range conditional formatting plus a Custom formula. The formula used "CoalesceEmpty()" to return 0 for empty cells. That returned value made the Range condition work as expected.
