I'm a little lost about generate custom Measures, I will ask for your help with two examples:
Example A: Display logged time depends of the project.
Example B: Display logged time depends of customfield value.
How can I wrote now a measure that depends of customfield value?
Thanks a lot for replies
Hi Marc,
You could try using tuples to create new user-defined calculated measures.
See more information about tuples here - in eazyBI documentation
https://docs.eazybi.com/display/EAZYBI/Calculated+members#Calculatedmembers-Tuples
Following MDX could be used create a new user-defined calculated measure that returns hours spent only in specific Project.
( [Measures].[Hours spent], [Status].CurrentMember, [Project].[JIRA Software (including JIRA Agile)] )
Similarly, you could approach with your custom fields and vice verse, if you have Project dimension in rows, you could address custom field specific value in the MDX tuple.
Please contact support@eazybi.com if you have further questions regarding this!
Martins Vanags / support@eazybi.com
