JIRA Automation Plugin, the Edit Fields screen mentions
Where can I get a full list of these variables? This looks to be very handy.
We are inserting the whole issue
object into the Velocity renderer. Most of built-in fields should work (such as priority
etc). You may be able to use similar variables as in email templates. Even branching is possible, same as in other Velocity files.
@Matej Konecny
Thank you for the response.
I'm not a programmer, but I think I the two "objects" that JIRA Automation Plugin sets are issue and custom fields (basically, those are additional fields for issues, in addition to the built-in fields).
EditIssueAction.java Excerpt:
context.put("issue", issue); context.put("customfields", new CustomFieldValueRetriever(customFieldManager, issue));
Are these the places to find the built-in fields?
What is branching? Is that like $issue.reporter? In fact, what I am trying to do is get to a reporter's group, or a reporter's custom properties. I will post that question separately. Thanks again.
The issue
object is passed as a GenericValue (GV) and Velocity uses public Getters to derive appropriate method similar to the logic here:
issue.getSummary() -> $issue.summary issue.getPriority().getName() -> $issue.priority.name (I think, never tested)
Basically, object of type https://docs.atlassian.com/jira/latest/com/atlassian/jira/issue/MutableIssue.html is passed, so in theory all methods starting with get
* should work.
You can use standard Velocity formatting template, look at this:
customfield_14080=#if($customfields.get(14080) == 'Urgency 5')13080#elseif($customfields.get(14080) == 'Urgency 4')13081#elseif($customfields.get(14080) == 'Urgency 3')13082#elseif($customfields.get(14080) == 'Urgency 2')13083#end
Make sure it's on one line though
Save your spot
