Edit SSO OpenID Connect Landing Page
Alin Ghita
March 19, 2024
How is it possible to have SSO OpenID integration along with standard user and pwd login, but hide the OpenID landing page ?
Basically hide this page :
Thank you,
Alin
Ananjan_miniOrange
March 19, 2024 edited
Hi Alin,
If you're aiming to personalize the JIRA login page and tweak what users see on the SSO button, Atlassian offers a feature to handle that.
Alternatively, if you're keen on customizing the entire login page with your code, you might want to check out our app mO Jira OAuth SSO, Jira OpenID Connect SSO, Jira OIDC SSO
Let me know if that clears things up for you!
PS: I work for miniOrange, the app mentioned above!
Alin Ghita
March 20, 2024
Hi Anjan,
Thank you for your answer, but the solution from Atlassian does not work : if I choose to not show the ldP on the login page (which is exactly what I need), the integration becomes disabled.
There is also a solution to alter the jira-gadgets-plugin, described here https://confluence.atlassian.com/jirakb/customize-jira-login-page-225122084.html but I was hoping for something easier that will not interfere with system plugins.
I will take a look at MiniOrange also and see what we can do.
Thank you,
Alin
Ananjan_miniOrange
March 20, 2024
@Alin Ghita I think there could be some configuration issue. However, You can raise a ticket with Atlassian using this link: Atlassian Support
If you need any setup assistance with the miniOrange app, feel free to email me at ananjan.mishra@xecurify.com, and I'll brief you in no time.
I hope that helps!
Register today
