×I need for individuals other than the original diagram creator to be able to edit a diagram. I have experimented with several different permissions settings, but the diagram is treated as an attachment and there are no permission settings for editing attachments. I can give everyone the ability to delete it, just not to edit it. The original creator is able to edit the attachment, but the edit icon is grayed out for other users. I am using version 1.2.3
Suggestions on how I can overcome this?
Currently, we allow users to edit the diagram if any of the following conditions are met :
We're open to suggestions on permission handling as long as they make sense.
Update
As of 4.0.0.0 edit permissions have been reworked. In order to be able to edit the diagram, user must have attachment deletion permissions.
This is because JIRA API does not properly support updates to attachments contents. Only create and delete operations are supported by the API.
Dear Boris,
Is there a posibility expand permission to use user custom field? For example users in user custom field 'Technical Writers' are able to edit / add diagrams? Tho, that would require some configuration UI.
Kind regards.
We are having the same issue where we are not able to edit other user's diagrams with drawio in Jira. Basically we were hoping that by assigning the issue to a user will allow that user will be able to edit the diagram but we have found this is not the case with our install. Any help or advice will be greatly appreciated. We have purchased the starter plugin for confluence but have not gotten around to installing it yet. We are thinking the alternative is to collaborate with attaching Visio diagrams or we can start looking into Gliffy. FYI - we are using drawio 4.1.0.0 with version 6.0.5 of jira.
I've updated my answer.
JIRA does support 'versioning' for Attachments.
I don't understand why the draw.io Plugin deletes the old versions of the diagrams. If a new file with the same name is added there will be created a new version of this file. So no one would need the "Delete all attachments"-Permission to edit Diagrams from other users.
There is no "update attachment" API call, at least, not when we last checked. Only, add and delete.
Via REST-API it simply works via adding a file with the same name again and again... JIRA then creates then a new version every time a new file is uploaded.
We make the create attachment call server-side, using AttachmentManager, https://docs.atlassian.com/software/jira/docs/api/8.0.3/com/atlassian/jira/issue/AttachmentManager.html.
I tested, but there's no way to do this server-side.
Client-side, are you certain these are new revisions of the same attachment, not new attachments with the same name? https://jira.atlassian.com/browse/JRASERVER-5963 suggests that Jira Server does not have attachment revisioning.
https://jira.atlassian.com/browse/JRASERVER-2169 eludes to the same problem. I assume you've tested making more than one REST API call to add an attachment with the same name? How did you confirm that the attachment had been updated in-place, instead of a new attachment created? i.e. what are the steps for me to reproduce?
Yes, I tested it via doing multiple REST API calls.
curl -D- -u jirauser:password -X POST -H "X-Atlassian-Token: no-check" -F "file=@foobar" https://YOURJIRAMACHINE/rest/api/2/issue/ISSUEKEY/attachments
In fact, uploading multiple files with identical name creates always new attachments. Nothing is deleted and nothing is 'updated'... JIRA simply allows to upload files with the same filename and creates always a new attachment-'Version' - in fact a new attachment with the same name - displaying them as multiple Versions.
So, 100 versions of the diagram would show 100 attachments to the issue? That's just wrong, users would hate this.
Currently our users don't like, that they cannot edit Draw.IO-Diagrams which were initially created by other users... the discussion in our company is to uninstall Draw.IO-Plugin because of that flaw.
We don't want to grant every user to delete all attachments in arbitray projects (JIRA permission Delete All Attachments vs. Delete Own Attachments).
The Solution for the Draw.IO-Plugin could be the following:
The Draw.IO-Plugin querys JIRA if the User has the permission to delete the previous attachment. If that's allowed Draw.IO offers 'Save Diagramm without new version" - otherwise Draw.IO creates a new Version.
We've added an item, https://trello.com/c/hWSUq7Eb/25-can-we-have-versioning-without-lots-of-attachments-visible, to investigate. Basically, there would need to be a method to hide the multiple attachments from the UI for us to be able to use it.
user is the assignee for the issue
For me this doesn't work. Also the reporter right makes no difference. I can only edit if I am author, or administrator
I have same issue. What type of administrator do i have to become to use this as a temporary work around? This almost seems like a deal breaker when dealing with wiki like technologies because you want regular users to be able to contribute to drawings. FYI - we are using drawio 4.1.0.0 with version 6.0.5 of jira.
Thanks, Boris. I couldn't find that documented anywhere and hadn't tried all those permutations yet.
It seems like adding a permission for "edit all attachments" or "edit all draw.io attachments" permission would be JIRA-friendly way of handling this.
