Email This Issue Handler Regex values
Pablo da Silva [ACP-JA]
March 22, 2018 edited
     I´m evaluating JETI's features regarding field initialization through incoming emails. When i test the regex against an example email within JETIS's rule ditor, it captures the values as expected. But when i send an actual email to set the fields (no matter is the isue exists or if it is created) the handler adds some characters before the actual field value (An * character and a white space).
I'm sure it is a really simple thing to resolve but i'm stucked, i tried other regex validators and they capture the values clean using the same expression.
Any ideas would be very appreciated,
I got it, it is an email issue, the email changes the content format, i have to address that on the regex expression..
Aniket Patil August 16, 2018
Hi Pablo,
I see that you are able to populate more than one field using this email handler plugin. I am unable to populate more than one field. I have the same regex. However, just the top most field gets populated:
The sample email's body:
@host:ABCD
on @server: DEFG
Regex functions used:
  • (?i)@host:(.*)
  • (?i)@server:(.*)
Group used: '1' for both of them.
The field that gets populated is just the host field but not the server field.
It would be great if you could provide more insight using your solution.
Hi Aniket,
                     I apologize for the delay, the above screen is the actual field rule setting. Looks like the the (?¡) was causing trouble. The four fields are populated correctly. The first one is a number, the second is the requester name and surname, the third is usually a text string, of a few words, and the fourth is the emails subject. With the above settings it all works fine, maybe you can try this syntax and see what happens.
Best Regards
Aniket Patil August 22, 2018
Thanks @Pablo da Silva [ACP-JA], really appreciate it! This helped a lot :)
Chethan GR
March 18, 2019
Hi Pablo,
I'm using the following regular expressions but the fields are not populated with the value.And all the fields are of text field.
Capture.PNG can you help me with this.
Chethan
Register now
