×Hi,
is there an option to enable the old Excel (HTML) export again?
We are using 7.2.0 Server (JIRA Core).
The new CSV export hast to many issues for us .
Dieter
Found solution in a comment of JRA-62115:
Stop JIRA instance
Navigate to $jirahome folder
Create jira-config.properties file if the file is not available in your $jirahome
Add jira.export.excel.enabled=true and save the file
Restart JIRA and test using excel export feature.
Here's the corresponding knowledge base article: https://confluence.atlassian.com/jirakb/jira-excel-export-of-issues-no-longer-opens-correctly-838403242.html
This doesn't seem to work for V7.2.10, tried multiple ways with no luck, export still only shows CSV.
Created the jira-config.properties file on my JIRA_HOME D:\Program Files\JIRA
I tried with and without quotes. Am I missing something?
Works fine with all 7.x systems I've got access to.
However, I know what you've done - D:\Program Files\JIRA is not your Jira home directory. The files in it tell me it's your Jira installation directory.
Have a look in Admin -> System Information, that will tell you where Jira home really is.
Son of a.... Right, The Application Data Folder is my Home ugh. Ok yep it works now.
Thank you for the quick response.
Greg
I am using JIRA 7.3.0 Server for excel export option i enabled Jira-config.properties file. But still excel export option not available please help me is there any other ways to back my excel export option in my JIRA 7.3.0
I believe its not working fot 7.2.5. Any idea for excel export option on 7.2.5?
What's not working? Have you tried the "fix"?
i stopped jira, create a property file for enable excel, and restart jira, but the excel export option doesnt show.
what do you mean by "fix"?
Sorry, the "fix" was an attempt to ask if you've applied the property file "fix". I should have been more clear.
It looks like Atlassian may have removed the export completely from 7.2.5, so the "fix" doesn't work any more as there's nothing for it to activate (although 7.2.5 also has a bug which has made them remove the whole release from the downloads)
I am testing JIRA 7.2.6 and was able to activate Excel export.
Hi Nic,
In JIRA 7.3.0 Server also not available Excel Export option. As per Doc i followed to created Jira-config.properties file and added jira.export.excel.enabled=true. But still not available this feature please tell me there is any other way as soon as possible
Venkatesh.
Did you get the spelling exactly right? jira-config, not Jira-config
CSV exports show the JIRA ID instead of the JIRA name for the "Epic Link" column. The workaround was to use Excel HTML exports instead.
Now this is getting deprecated in the future. Is there a workaround to still show JIRA names for the Epic Link, in the CSV exports?
Source: How to export "Epic Link" with all fields (KEY and NAME)?
We also upgraded to V7.2.3 and I re-enabled the Excel export; however, my test shows that the 1000 export records restriction is no longer in place.
My test query returns almost 5000 records and when using the Export Excel, JIRA sends all the 5000 entries to the Excel sheet. It is no longer truncated to 1000 entries as before.
This can cause performance issues.
Do you see the same results in your environments?
Thanks Dieter for sharing the solution.
Worked for me with JIRA 7.2.3
