When trying to use a Epic->Story-> Subtask hierarchy I can not get the time reported on the Subtask to auto populate on the Story issue.
I like the way that Sub-tasks link to Stories on a Kanban board. I want the Story to remain present and the subtasks to move through a swim lane.
Does anyone have any suggestions to fix this? I tried to use tasks instead of subtasks. This fixes the time roll-up issue but the tasks do not roll up under the stories like the subtasks do.
You should be able to roll up time logged from Sub-task to Parent. You have a checkbox to do so.
This panel should be displayed as long as you have an estimate/ time logged on the task or one of the sub-task.
You cannot roll up to the Epic level . It will require an app for that. You can test app related to "Time Tracking"
WorklogPro seems to do it but there is propably other app that do it too.
https://thestarware.atlassian.net/wiki/spaces/WLP/pages/24477733/Time+Tracking+Panel
Hi @Florian Bonniec I hope all is well
I have the same issue and the include sub-task tick box does not appear on the main story that the sub-task is included
I am using the newer Jira view not sure if this is the issue or if I should add that as a field on the story?
Hi
What do you mean by "newer Jira view" ? Are you on Cloud or Data Center version ? What is your JIRA version ?
Do you have sub-tasks under the task ?
Regards
Hi
Thanks for the promt reply - we are on the Cloud version
The link you shared above is the "old Jira view"
We are on the newer view and while I have created sub tasks under a story there is no field option to check for the estimate from sub tasks to shown /track to the main story
Please see below the fields I see on the main story (there are 5 subtasks in that story all estimated 1h each - it is a test ticket we are trying to solve the same issue as mentioned on that thread)
Thanks again any help would be much appreciated :)
Hi @[deleted]
I think you are facing this bug, https://jira.atlassian.com/browse/JRACLOUD-70150.
Regards
Hi @Florian Bonniec
Thanks for looking into this more but we are missing one step
On our Jira we don't even see the field to have the check-box that says "include sub-tasks" this is not present as seen below
Any thougths of how we could activate that one?
Thank you
Theo
I am successful with this automation, rolling my subtask time estimate into my task time estimate. But my task time estimate is not rolling up into my epic.
Hopefully this can help you, and someone can help me with my challenges.
I have three levels:
Epic
Task
Subtask
1
2
3
One two and 3 total Original Estimate = 10hours
10 hours is reflected in my Task Original Time Estimate
But that 10 Hours is not reflected in Epic, Epic shows 0 (Zero)
