Hi Team,
I have 2 boards in the project.
one board has normal filter query (Board A)
In another board we want only issues to be displayed of one particular epic.(Board B).
(Project=ABC AND Epic Name="XYZ").--->this is filter query for Board B
when i create the epic(XYZ) in the Board B ,epic is not visible in board B But it is visible in the Board A.
It is showing that this epic can't be visible in Board B.
Kindly help.
Abhishree Nagesh
Hi ,
Thanks for ur quick response,
I was writing wrong epic Name.
Now its displaying in Both the board, which i dn't want .
I want ABC epic should be only visble in Board B in Epic Pannel.
If i make Epic as done in Board A , It will be not visible in both the Boards.
should i change the filter query in Board A(Epic name != ABC)
Abhishree Nagesh.
