Epic panel is showing multiple projects
Maya S Chase
June 1, 2015
We have a scrum board for a large project that is using Epics, and their Epic panel is showing Epics from every project in JIRA, not just their project.  I can't imagine that is the intended behavior!  The filter for the board specifies that the issues are only for that one project, so it makes no sense for the Epic panel to show all these extraneous Epics.  How do we make the Epic panel show only Epics from this one project?
Prem Chudzinski _extensi_
HI @Maya S Chase
You can filter the panel using our add-on the Agile Board Filter
The filter includes project names.
Christian Czaia [Decadis AG]
June 1, 2015
Hi, I think something is wrong with your filter. Usually, if an epic is not returned by a filter it will not be shown on a board or in the panel respectively.
Learn more
