Error Atlassian Plugin SDK 8.0.0
gia01020304 February 16, 2019
In sdk 8.0.0 I run atlas-mvn eclipse:eclipse and receive error messages like the image below
Tom Lister
is Primas your project name?
are you in the plugin directory?
Thank for Response, In sdk 6. use normal but in 8.0.0 error
Tom Lister
Hi
I just tried this on my mac and it worked so it's not  a general SDK problem I guess
[INFO] Not writing settings - defaults suffice
[INFO] Wrote Eclipse project for "MyFirst8" to /Users/tomlister/SDKDev/MyFirst8.
[INFO
       Sources for some artifacts are not available.
       List of artifacts without a source archive:
         o com.atlassian.jira:jira-api:7.13.0
         o com.atlassian.gadgets:atlassian-gadgets-api:4.2.32
         o com.atlassian.analytics:analytics-api:5.6.2
       Javadoc for some artifacts is not available.
       List of artifacts without a javadoc archive:
[INFO] ------------------------------------------------------------------------
[INFO] BUILD SUCCESS
[INFO] Total time: 23.089 s
[INFO] Finished at: 2019-02-16T11:41:29Z
Toms-MBP-3:MyFirst8 tomlister$
Tom Lister
is your project created by SDK 8?
Tom Lister
Hi
A couple of things I had to change to fix other '6' to '8' issues today. May not be related but just FYI
Change
<artifactId>maven-jira-plugin</artifactId>
to
<artifactId>jira-maven-plugin</artifactId>
Change
<amps.version>6.3.15</amps.version>
to
<amps.version>8.0.0</amps.version>
I also had to run an atlas-clean command.
gia01020304 February 25, 2019
Thank for support. I had resolved my problem by remove atlas- in my command
From atlas-mvn eclipse:eclipse to mvn eclipse:eclipse
