×Hi
While doing CSV import on jira, i am getting this error.
Can you please help?
Pls find the error log below.
2014-01-10 14:37:03,540 WARN - Exception occurred parsing comment. Some values may not be set java.text.ParseException: Unparseable date: "Analysis Comment :- 07/02/2009 19:01:31 G?rard De Mdfdfitte (gdedfdfdi) In lightddsfdux.c, around line 10355-13060, replace : s_lightdemuxSendMessage( (TLightdemuxFunction)filterdata->xReceivedSectionCallback, (u_int32)filterdata->pxBuffer, (errfound==0) ? EPGLIB_SECTION_BODY_SUCCESS : EPGLIB_SECTION_BODY_FAILED, 0, 0 )" at java.text.DateFormat.parse(DateFormat.java:337) at com.atlassian.jira.plugins.importer.imports.csv.CsvConfigBean.parseDate(CsvConfigBean.java:964) at com.atlassian.jira.plugins.importer.imports.csv.CsvConfigBean.parseDate(CsvConfigBean.java:959) at com.atlassian.jira.plugins.importer.imports.csv.mappers.SimpleCommentMapper.parseComment(SimpleCommentMapper.java:67) at com.atlassian.jira.plugins.importer.imports.csv.mappers.SimpleCommentMapper.buildFromMultiMap(SimpleCommentMapper.java:48) at com.atlassian.jira.plugins.importer.imports.csv.CsvDataBean.populateCache(CsvDataBean.java:207) at com.atlassian.jira.plugins.importer.imports.csv.CsvDataBean.refreshCache(CsvDataBean.java:133) at com.atlassian.jira.plugins.importer.imports.csv.CsvDataBean.getAllProjects(CsvDataBean.java:121) at com.atlassian.jira.plugins.importer.imports.csv.CsvDataBean.getSelectedProjects(CsvDataBean.java:127) at com.atlassian.jira.plugins.importer.imports.importer.impl.DefaultJiraDataImporter.preImport(DefaultJiraDataImporter.java:485) at com.atlassian.jira.plugins.importer.imports.importer.impl.DefaultJiraDataImporter.doImport(DefaultJiraDataImporter.java:262) at com.atlassian.jira.plugins.importer.imports.importer.impl.ImporterCallable.call(ImporterCallable.java:27) at com.atlassian.jira.plugins.importer.imports.importer.impl.ImporterCallable.call(ImporterCallable.java:16) at com.atlassian.jira.task.TaskManagerImpl$TaskCallableDecorator.call(TaskManagerImpl.java:366) at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303) at java.util.concurrent.FutureTask.run(FutureTask.java:138) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441) at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303) at java.util.concurrent.FutureTask.run(FutureTask.java:138) at com.atlassian.multitenant.impl.DefaultMultiTenantManager.runForTenant(DefaultMultiTenantManager.java:61) at com.atlassian.multitenant.juc.MultiTenantExecutors$WrappedRunnable.run(MultiTenantExecutors.java:160) at com.atlassian.jira.task.ForkedThreadExecutor$ForkedRunnableDecorator.run(ForkedThreadExecutor.java:249) at java.lang.Thread.run(Thread.java:662) 2014-01-10 14:37:03,603 WARN - Exception occurred parsing comment. Some values may not be set
hello,
you need to correct the encoding of you csv file and/or fix the missing separator
"Gérard" is incorrectly encoded and or present in the wrong column.
best regards,
