Error Connection with Database
venugopal123
I have migrated jira in Linux Environment and i map the Jira home directory & Dbconfig.Xml to New JIRA . But its still asking the Application Properties UI of JIRA server in Browser . Suppose if it really reads the data from database it should not ask for the remaind details sucha as application properties , setup db etc..
But here its asking for application proprties why am not getting .
I have check the catalina.out log file : here "Error importing the data: could not find the column 'Exclude_issue_details' in previously parsed query '"
Please find the attached Screenshot of error message,Dbconfig.xml  and log messages .Please help me to fix this.Yur quick response is highly appreciated
Catalina.out:
2017-10-03 16:30:02,091 http-nio-8080-exec-3 INFO anonymous 990x4x1 1rs9oji 199.63.92.5 /secure/SetupDatabase!default.jspa [c.a.j.bc.dataimport.DefaultDataImportService] Running JIRA Data Import...
2017-10-03 16:30:02,111 http-nio-8080-exec-3 INFO anonymous 990x4x1 1rs9oji 199.63.92.5 /secure/SetupDatabase!default.jspa [c.a.j.bc.dataimport.DefaultDataImportService] Importing XML data...
2017-10-03 16:30:02,199 http-nio-8080-exec-3 DEBUG anonymous 990x4x1 1rs9oji 199.63.92.5 /secure/SetupDatabase!default.jspa [c.a.activeobjects.osgi.ActiveObjectsServiceFactory] startCleaning
2017-10-03 16:30:02,282 http-nio-8080-exec-3 DEBUG anonymous 990x4x1 1rs9oji 199.63.92.5 /secure/SetupDatabase!default.jspa [c.a.activeobjects.osgi.ActiveObjectsServiceFactory] stopCleaning
2017-10-03 16:30:02,282 http-nio-8080-exec-3 ERROR anonymous 990x4x1 1rs9oji 199.63.92.5 /secure/SetupDatabase!default.jspa [c.a.j.bc.dataimport.DefaultDataImportService] Error importing data: java.lang.IllegalStateException: Could not find column 'EXCLUDE_ISSUE_DETAILS' in previously parsed query!
at net.java.ao.schema.helper.DatabaseMetaDataReaderImpl.getFields(DatabaseMetaDataReaderImpl.java:118)
at net.java.ao.schema.ddl.SchemaReader.readFields(SchemaReader.java:126)
at net.java.ao.schema.ddl.SchemaReader.readTable(SchemaReader.java:110)
at net.java.ao.schema.ddl.SchemaReader.access$000(SchemaReader.java:62)
at net.java.ao.schema.ddl.SchemaReader$1.apply(SchemaReader.java:99)
at net.java.ao.schema.ddl.SchemaReader$1.apply(SchemaReader.java:97)
at com.google.common.collect.Iterators$8.transform(Iterators.java:799)
at com.google.common.collect.TransformedIterator.next(TransformedIterator.java:48)
at com.google.common.collect.Iterators.addAll(Iterators.java:362)
at com.google.common.collect.Lists.newArrayList(Lists.java:160)
at com.google.common.collect.Lists.newArrayList(Lists.java:144)
at net.java.ao.schema.ddl.SchemaReader.readSchema(SchemaReader.java:97)
at net.java.ao.schema.ddl.SchemaReader.readSchema(SchemaReader.java:88)
at net.java.ao.schema.ddl.SchemaReader.readSchema(SchemaReader.java:81)
at com.atlassian.activeobjects.backup.ActiveObjectsDatabaseCleaner.doCleanup(ActiveObjectsDatabaseCleaner.java:58)
at com.atlassian.activeobjects.backup.ActiveObjectsDatabaseCleaner.cleanup(ActiveObjectsDatabaseCleaner.java:45)
at com.atlassian.activeobjects.backup.ActiveObjectsBackup.clear(ActiveObjectsBackup.java:160)
at com.atlassian.jira.bc.dataimport.DefaultDataImportService.removeActiveObjects(DefaultDataImportService.java:984)
at com.atlassian.jira.bc.dataimport.DefaultDataImportService.performImport(DefaultDataImportService.java:704)
at com.atlassian.jira.bc.dataimport.DefaultDataImportService.doImport(DefaultDataImportService.java:324)
at com.atlassian.jira.startup.DatabaseInitialImporter.importInitialData(DatabaseInitialImporter.java:56)
at com.atlassian.jira.startup.DatabaseInitialImporter.importInitialData(DatabaseInitialImporter.java:48)
at com.atlassian.jira.web.action.setup.SetupDatabase.doDefault(SetupDatabase.java:141)
... 3 filtered
at java.lang.reflect.Method.invoke(Method.java:498)
at webwork.util.InjectionUtils$DefaultInjectionImpl.invoke(InjectionUtils.java:70)
at webwork.util.InjectionUtils.invoke(InjectionUtils.java:56)
... 2 filtered
at com.atlassian.jira.action.JiraActionSupport.execute(JiraActionSupport.java:63)
... 7 filtered
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
... 56 filtered
at com.atlassian.web.servlet.plugin.request.RedirectInterceptingFilter.doFilter(RedirectInterceptingFilter.java:21)
... 58 filtered
at com.atlassian.jira.security.JiraSecurityFilter.lambda$doFilter$0(JiraSecurityFilter.java:76)
... 1 filtered
at com.atlassian.jira.security.JiraSecurityFilter.doFilter(JiraSecurityFilter.java:74)
... 36 filtered
at com.atlassian.jira.servermetrics.CorrelationIdPopulatorFilter.doFilter(CorrelationIdPopulatorFilter.java:30)
... 10 filtered
... 4 filtered
at com.atlassian.web.servlet.plugin.LocationCleanerFilter.doFilter(LocationCleanerFilter.java:36)
... 29 filtered
at com.atlassian.jira.servermetrics.MetricsCollectorFilter.doFilter(MetricsCollectorFilter.java:25)
... 27 filtered
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:745)
2017-10-03 16:30:02,304 http-nio-8080-exec-3 INFO anonymous 990x4x1 1rs9oji 199.63.92.5 /secure/SetupDatabase!default.jspa [c.a.j.bc.dataimport.DefaultDataImportService] JIRA Data Import has finished.
2017-10-03 16:30:02,304 http-nio-8080-exec-3 ERROR anonymous 990x4x1 1rs9oji 199.63.92.5 /secure/SetupDatabase!default.jspa [c.a.jira.startup.DatabaseInitialImporter]
2017-10-03 16:30:02,305 http-nio-8080-exec-3 ERROR anonymous 990x4x1 1rs9oji 199.63.92.5 /secure/SetupDatabase!default.jspa [c.a.jira.startup.DatabaseInitialImporter] Error importing data: java.lang.IllegalStateException: Could not find column 'EXCLUDE_ISSUE_DETAILS' in previously parsed query!Error while connecting with DB.png DbConfig.Xml.png
Nic Brough -Adaptavist-
October 3, 2017
Also check if you're running this stuff as "root".  It should not be run as root, and if you do run it that way, it clobbers all sorts of stuff.
scherbank
I would suggest to check db user permissions. The issue doesn't look like that but it cost nothing to check that.
Register now
