Error during setup: Jira Cloud for Sheets
Stefan Warries
February 6, 2020
So i'm trying to setup: "Jira Cloud for Sheets"
My corporate IT department allowed me to add the add-on to Google Sheets.
Once i add the addon and i click on: "Connect to Jira" it opens a new tab showing me an error:
Authorize App
Something went wrong
You don't have an Atlassian Jira & User identity site to connect Jira Cloud for Spreadsheets to.
It's very unclear what an "Atlassian Jira & User identity site" is.
I can't find anything about it
Anybody any idea?
Best,
Stefan
Maya Assayag May 23, 2024
Hi, I'm experiencing the same issue. I believe it's a scope problem since I'm getting this error during the OAuth flow with a 409 conflict status code. Does anyone know the solution?
Yong
I have met with the same issue, but don't know the reason.
Earl McCutcheon
February 7, 2020
Hello @Stefan Warries ,
The error you are encountering:
Mentions you do not have access to the User Identity Site.  The identity management system is the user management for Jira cloud accounts indicating that the user account you have logged into the google sheet, does not have access to any Jira cloud sites.
Make sure you are logged into your browser with the account that you use to log into the cloud site so that the tool can connect the account to the sheet.
Also, you have selected Unknown Hosting Type when creating this post, and the google  add-on "Jira Cloud for Sheets" is only avaliable for a JIra cloud instances and would not be compatible with a server deployment of the application.  Can you confirm if you are you on Jira Server or Cloud?
To tell the difference between jira cloud and server, a cloud instance will hav a "atlassian.net" domain in the url like "http://your_site_name.atlassian.net" where a server installation will have a custom domain name
If you are on Jira server and you are looking for a similar add-on you could look into something like the Google Sheets Integration third party tool that has similar functions and is designed for jira server compatibility.
Earl
Adam Stein
I just ran into this as well, and I'm using Jira Cloud. The fix was to log out of Jira and log back in...
Like Margareth Firmino Benzi likes this
