×Hello.
I am using JSD 4.0.2 and Jira Core 8.0.2.
I am trying to enable a plugin in my Jira (NTX Plugin) but I am getting errors.
org.springframework.beans.factory.BeanDefinitionStoreException: Failed to parse configuration class [com.atlassian.ntx.utils.PropertiesSetup]; nested exception is java.io.FileNotFoundException: OSGi resource[classpath:com/atlassian/plugin/web/baseconditions/BaseCondition.class|bnd.id=236|bnd.sym=com.atlassian.ntx.ntxUI] cannot be resolved to URL because it does not exist
Can you help me with this?
Errors:
2019-03-25 14:38:55,559 ThreadPoolAsyncTaskExecutor::Thread 38 ERROR admin 878x587x1 9rmu72 0:0:0:0:0:0:0:1 /rest/plugins/1.0/ [c.a.p.osgi.factory.OsgiPlugin] Unable to start the plugin container for plugin 'com.atlassian.ntx.ntxUI' org.springframework.beans.factory.BeanDefinitionStoreException: Failed to parse configuration class [com.atlassian.ntx.utils.PropertiesSetup]; nested exception is java.io.FileNotFoundException: OSGi resource[classpath:com/atlassian/plugin/web/baseconditions/BaseCondition.class|bnd.id=236|bnd.sym=com.atlassian.ntx.ntxUI] cannot be resolved to URL because it does not exist at org.springframework.context.annotation.ConfigurationClassParser.parse(ConfigurationClassParser.java:184) at org.springframework.context.annotation.ConfigurationClassPostProcessor.processConfigBeanDefinitions(ConfigurationClassPostProcessor.java:316) at org.springframework.context.annotation.ConfigurationClassPostProcessor.postProcessBeanDefinitionRegistry(ConfigurationClassPostProcessor.java:233) ... at org.eclipse.gemini.blueprint.extender.internal.activator.LifecycleManager$1.run(LifecycleManager.java:213) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at java.lang.Thread.run(Thread.java:748) Caused by: java.io.FileNotFoundException: OSGi resource[classpath:com/atlassian/plugin/web/baseconditions/BaseCondition.class|bnd.id=236|bnd.sym=com.atlassian.ntx.ntxUI] cannot be resolved to URL because it does not exist at org.eclipse.gemini.blueprint.io.OsgiBundleResource.getURL(OsgiBundleResource.java:229) at org.eclipse.gemini.blueprint.io.OsgiBundleResource.getInputStream(OsgiBundleResource.java:181) ... at org.springframework.context.annotation.ConfigurationClassParser.parse(ConfigurationClassParser.java:176) ... 15 more
@Fr0zt Adding com.atlassian.plugin.web.baseconditions to Import-Package in the jira-maven-plugin config fixed this for me.
<Import-Package>
com.atlassian.jira.event,
com.atlassian.plugin.web.baseconditions,
</Import-Package>
After adding the baseconditions package I had another similar error with events and adding the event package fix that as well.
I don't understand why this was working before...
Thanks @Tobias Binna
This worked for me. I had the same issue upgrading my plugins from Jira core 7.13.1 to 8.18.2
Is this problem happening in a new installation of Jira 8.0.2 or was Jira working in this version for some time before this problem started happening?
Could you run the following SQL command on the Jira database and let us know the results?
select * from pluginstate;
This will return to us a listing of all plugins in Jira that have been flagged on a database level to be disabled. I would expect any plugins you manually disabled to appear here, but I am interested to learn if one or more system plugins might exist on this list and in turn not be getting loaded up when Jira starts.
Andy
Similar issue here. Seeing this when trying to make app compatible with Jira 8.1.1
nested exception is java.io.FileNotFoundException: OSGi resource[classpath:com/atlassian/plugin/web/baseconditions/BaseCondition.class|bnd.id=218|bnd.sym=io.toolsplus.intercom-for-jira-server] cannot be resolved to URL because it does not exist
[INFO] [talledLocalContainer] OSGi resource[classpath:com/atlassian/plugin/web/baseconditions/BaseCondition.class|bnd.id=218|bnd.sym=io.toolsplus.intercom-for-jira-server] cannot be resolved to URL because it does not exist
Pluginstate query above does not return anything. No records in DB.
