Error found after upgrading jira from 7.2.5 To 7.5.0
achref_bziouech
Hello Jira Masters ,
i found this error after upgrading Jira version from 7.2.5 to 7.5.0 :
2017-09-27 10:20:35,155 Caesium-1-4 ERROR      [c.a.upgrade.core.DefaultUpgradeTaskFactoryProcessor] Upgrade task [host,buildNumber=73011] failed
com.querydsl.core.QueryException: Caught SQLSyntaxErrorException for insert into OS_CURRENTSTEP (ID, ENTRY_ID, STEP_ID, ACTION_ID, OWNER, START_DATE, DUE_DATE, FINISH_DATE, STATUS, CALLER)
select hs.ID, hs.ENTRY_ID, hs.STEP_ID, hs.ACTION_ID, hs.OWNER, hs.START_DATE, hs.DUE_DATE, null, hs.STATUS, hs.CALLER
from OS_HISTORYSTEP hs
where hs.ENTRY_ID in (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?) and exists (select ISSUE.id
from jiraissue ISSUE
where ISSUE.workflow_id = hs.ENTRY_ID and not exists (select OS_CURRENTSTEP.ID
from OS_CURRENTSTEP OS_CURRENTSTEP
where OS_CURRENTSTEP.ENTRY_ID = ISSUE.workflow_id)) and hs.ID = (select * from (
  select hs2.ID
from OS_HISTORYSTEP hs2
where hs.ENTRY_ID = hs2.ENTRY_ID and hs2.FINISH_DATE is not null and not exists (select prevStep.ID
from OS_HISTORYSTEP_PREV prevStep
where prevStep.PREVIOUS_ID = hs2.ID)
order by hs2.FINISH_DATE desc
) where rownum <= ?) and (select * from (
  select count(hs2.FINISH_DATE)
group by hs2.FINISH_DATE
) where rownum <= ?) = ?
        at com.querydsl.sql.DefaultSQLExceptionTranslator.translate(DefaultSQLExceptionTranslator.java:50)
        at com.querydsl.sql.Configuration.translate(Configuration.java:459)
        at com.querydsl.sql.dml.SQLInsertClause.execute(SQLInsertClause.java:445)
        at com.atlassian.jira.upgrade.tasks.UpgradeTask_Build73011.lambda$restoreEntriesFromHistory$3(UpgradeTask_Build73011.java:231)
        at com.atlassian.jira.upgrade.tasks.UpgradeTask_Build73011$$Lambda$994/353337797.runQuery(Unknown Source)
        at com.atlassian.jira.database.DefaultQueryDslAccessor.lambda$executeQuery$0(DefaultQueryDslAccessor.java:68)
        at com.atlassian.jira.database.DefaultQueryDslAccessor$$Lambda$517/291225287.apply(Unknown Source)
        at com.atlassian.jira.database.DatabaseAccessorImpl.lambda$runInTransaction$0(DatabaseAccessorImpl.java:99)
        at com.atlassian.jira.database.DatabaseAccessorImpl$$Lambda$518/767133039.run(Unknown Source)
        at com.atlassian.jira.database.DatabaseAccessorImpl.executeQuery(DatabaseAccessorImpl.java:68)
        at com.atlassian.jira.database.DatabaseAccessorImpl.runInTransaction(DatabaseAccessorImpl.java:94)
        at com.atlassian.jira.database.DefaultQueryDslAccessor.executeQuery(DefaultQueryDslAccessor.java:67)
        at com.atlassian.jira.upgrade.tasks.UpgradeTask_Build73011.restoreEntriesFromHistory(UpgradeTask_Build73011.java:197)
        at com.atlassian.jira.upgrade.tasks.UpgradeTask_Build73011.runUpgrade(UpgradeTask_Build73011.java:98)
        at com.atlassian.upgrade.core.DefaultUpgradeTaskFactoryProcessor.runOneUpgradeTask(DefaultUpgradeTaskFactoryProcessor.java:109)
        at com.atlassian.upgrade.core.DefaultUpgradeTaskFactoryProcessor.lambda$performUpgradesUnsafe$13(DefaultUpgradeTaskFactoryProcessor.java:80)
        at com.atlassian.upgrade.core.DefaultUpgradeTaskFactoryProcessor$$Lambda$956/1155445222.test(Unknown Source)
        at java.util.stream.ReferencePipeline$2$1.accept(ReferencePipeline.java:174)
        at java.util.stream.SortedOps$RefSortingSink.end(SortedOps.java:395)
        at java.util.stream.Sink$ChainedReference.end(Sink.java:258)
        at java.util.stream.AbstractPipeline.copyIntoWithCancel(AbstractPipeline.java:530)
        at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:516)
        at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:502)
        at java.util.stream.FindOps$FindOp.evaluateSequential(FindOps.java:152)
        at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234)
        at java.util.stream.ReferencePipeline.findFirst(ReferencePipeline.java:464)
        at com.atlassian.upgrade.core.DefaultUpgradeTaskFactoryProcessor.performUpgradesUnsafe(DefaultUpgradeTaskFactoryProcessor.java:81)
        at com.atlassian.upgrade.core.DefaultUpgradeTaskFactoryProcessor.performUpgrades(DefaultUpgradeTaskFactoryProcessor.java:46)
        at com.atlassian.upgrade.core.DefaultUpgradeTaskManager.upgradeHostApp(DefaultUpgradeTaskManager.java:41)
        at com.atlassian.jira.upgrade.LicenseCheckingUpgradeService.executeUpgrades(LicenseCheckingUpgradeService.java:134)
        at com.atlassian.jira.upgrade.LicenseCheckingUpgradeService.runUpgrades(LicenseCheckingUpgradeService.java:97)
        at com.atlassian.jira.upgrade.ClusterLockingUpgradeService.runUpgrades(ClusterLockingUpgradeService.java:35)
        at com.atlassian.jira.upgrade.LoggingUpgradeService.lambda$runUpgradesWithLogging$0(LoggingUpgradeService.java:28)
        at com.atlassian.jira.upgrade.LoggingUpgradeService$$Lambda$939/678203302.get(Unknown Source)
        at com.atlassian.jira.upgrade.LoggingUpgradeService.runWithTaskLogging(LoggingUpgradeService.java:43)
        at com.atlassian.jira.upgrade.LoggingUpgradeService.runUpgradesWithLogging(LoggingUpgradeService.java:28)
        at com.atlassian.jira.upgrade.IndexingUpgradeService.runUpgrades(IndexingUpgradeService.java:19)
        at com.atlassian.jira.upgrade.UpgradeScheduler.runHostUpgrades(UpgradeScheduler.java:95)
        at com.atlassian.jira.upgrade.UpgradeScheduler.runUpgrades(UpgradeScheduler.java:76)
        at com.atlassian.jira.upgrade.UpgradeScheduler$$Lambda$291/1923432757.runJob(Unknown Source)
        at com.atlassian.scheduler.core.JobLauncher.runJob(JobLauncher.java:153)
        at com.atlassian.scheduler.core.JobLauncher.launchAndBuildResponse(JobLauncher.java:118)
        at com.atlassian.scheduler.core.JobLauncher.launch(JobLauncher.java:97)
        at com.atlassian.scheduler.caesium.impl.CaesiumSchedulerService.launchJob(CaesiumSchedulerService.java:443)
        at com.atlassian.scheduler.caesium.impl.CaesiumSchedulerService.executeClusteredJob(CaesiumSchedulerService.java:438)
        at com.atlassian.scheduler.caesium.impl.CaesiumSchedulerService.executeClusteredJobWithRecoveryGuard(CaesiumSchedulerService.java:462)
        at com.atlassian.scheduler.caesium.impl.CaesiumSchedulerService.executeQueuedJob(CaesiumSchedulerService.java:390)
        at com.atlassian.scheduler.caesium.impl.CaesiumSchedulerService$1.consume(CaesiumSchedulerService.java:285)
        at com.atlassian.scheduler.caesium.impl.CaesiumSchedulerService$1.consume(CaesiumSchedulerService.java:282)
        at com.atlassian.scheduler.caesium.impl.SchedulerQueueWorker.executeJob(SchedulerQueueWorker.java:65)
        at com.atlassian.scheduler.caesium.impl.SchedulerQueueWorker.executeNextJob(SchedulerQueueWorker.java:59)
        at com.atlassian.scheduler.caesium.impl.SchedulerQueueWorker.run(SchedulerQueueWorker.java:34)
        at java.lang.Thread.run(Thread.java:745)
Caused by: java.sql.SQLSyntaxErrorException: ORA-00904: "HS"."ENTRY_ID": invalid identifier
        at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:450)
        at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:399)
        at oracle.jdbc.driver.T4C8Oall.processError(T4C8Oall.java:1059)
        at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:522)
        at oracle.jdbc.driver.T4C8Oall.doOALL(T4C8Oall.java:587)
        at oracle.jdbc.driver.T4CPreparedStatement.doOall8(T4CPreparedStatement.java:225)
        at oracle.jdbc.driver.T4CPreparedStatement.doOall8(T4CPreparedStatement.java:53)
        at oracle.jdbc.driver.T4CPreparedStatement.executeForRows(T4CPreparedStatement.java:943)
        at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1150)
        at oracle.jdbc.driver.OraclePreparedStatement.executeInternal(OraclePreparedStatement.java:4798)
        at oracle.jdbc.driver.OraclePreparedStatement.executeUpdate(OraclePreparedStatement.java:4875)
        at oracle.jdbc.driver.OraclePreparedStatementWrapper.executeUpdate(OraclePreparedStatementWrapper.java:1361)
        at org.apache.commons.dbcp2.DelegatingPreparedStatement.executeUpdate(DelegatingPreparedStatement.java:98)
        at com.querydsl.sql.dml.SQLInsertClause.execute(SQLInsertClause.java:423)
        ... 50 more
Can you help please ?
thank you
Shannon S
September 28, 2017
Hi there,
Are you able to run the Database Integrity Checker, correct any issues, and then do a locked reindex of JIRA
Let us know once you've done that if you're still encountering any problems.
Kind Regards,
Shannon
achref_bziouech
Hello Shannon,
Integrity cheker is not working . i got this error :
achref_bziouech
Technical details
Log's referral number: 2703be36-ff23-42de-a6f0-fd591db261c1
Cause
Referer URL: http://gandalf.imxbg:8080/secure/admin/IntegrityChecker!default.jspa
com.atlassian.jira.appconsistency.integrity.exception.IntegrityException: Error occurred while performing check.
Shannon S
September 28, 2017
Thank you! There are a few things that can cause that; are you able to show us what occurs in the logs after the line you sent above?
Can you see if you can run only RelatedOSWorkflowEntry check first, and then fix any returned entries, and then run the rest of the checks?
Kind Regards,
Shannon
achref_bziouech
 at com.atlassian.jira.appconsistency.integrity.check.AbstractEntityRelation.preview(AbstractEntityRelation.java:57) [classes/:?]
 at com.atlassian.jira.appconsistency.integrity.IntegrityChecker.preview(IntegrityChecker.java:52) [classes/:?]
 at com.atlassian.jira.appconsistency.integrity.IntegrityChecker.previewWithIds(IntegrityChecker.java:29) [classes/:?]
 at com.atlassian.jira.web.action.admin.IntegrityChecker.doExecute(IntegrityChecker.java:56) [classes/:?]
 at webwork.action.ActionSupport.execute(ActionSupport.java:165) [webwork-1.4-atlassian-30.jar:?]
 at com.atlassian.jira.action.JiraActionSupport.execute(JiraActionSupport.java:63) [jira-api-7.5.0.jar:?]
 at webwork.interceptor.DefaultInterceptorChain.proceed(DefaultInterceptorChain.java:39) [webwork-1.4-atlassian-30.jar:?]
 at webwork.interceptor.NestedInterceptorChain.proceed(NestedInterceptorChain.java:31) [webwork-1.4-atlassian-30.jar:?]
 at webwork.interceptor.ChainedInterceptor.intercept(ChainedInterceptor.java:16) [webwork-1.4-atlassian-30.jar:?]
 at webwork.interceptor.DefaultInterceptorChain.proceed(DefaultInterceptorChain.java:35) [webwork-1.4-atlassian-30.jar:?]
 at webwork.dispatcher.GenericDispatcher.executeAction(GenericDispatcher.java:225) [webwork-1.4-atlassian-30.jar:?]
 at webwork.dispatcher.GenericDispatcher.executeAction(GenericDispatcher.java:154) [webwork-1.4-atlassian-30.jar:?]
 at com.atlassian.jira.web.dispatcher.JiraWebworkActionDispatcher.service(JiraWebworkActionDispatcher.java:138) [classes/:?]
 at javax.servlet.http.HttpServlet.service(HttpServlet.java:729) [servlet-api.jar:?]
 at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:230) [catalina.jar:8.5.6]
 at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:165) [catalina.jar:8.5.6]
 at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52) [tomcat-websocket.jar:8.5.6]
 at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:192) [catalina.jar:8.5.6]
 at com.atlassian.jira.web.filters.JiraLastFilter.lambda$doFilter$0(JiraLastFilter.java:39) [classes/:?]
 at com.atlassian.jira.web.filters.JiraLastFilter$$Lambda$641/1236279630.doFilter(Unknown Source) [?:?]
 at com.atlassian.jira.web.filters.steps.ChainedFilterStepRunner.doFilter(ChainedFilterStepRunner.java:74) [classes/:?]
 at com.atlassian.jira.web.filters.JiraLastFilter.doFilter(JiraLastFilter.java:36) [classes/:?]
 at com.atlassian.jira.web.filters.XContentTypeOptionsNoSniffFilter.doFilter(XContentTypeOptionsNoSniffFilter.java:20) [classes/:?]
 at com.atlassian.core.filters.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:32) [atlassian-core-5.0.8.jar:?]
 at com.atlassian.core.filters.HeaderSanitisingFilter.doFilter(HeaderSanitisingFilter.java:37) [atlassian-core-5.0.8.jar:?]
 at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:39) [atlassian-plugins-servlet-4.5.0.jar:?]
 at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter$1.doFilter(DelegatingPluginFilter.java:58) [atlassian-plugins-servlet-4.5.0.jar:?]
 at com.atlassian.jira.onboarding.postsetup.ui.PostSetupAnnouncementsFilter.doFilter(PostSetupAnnouncementsFilter.java:51) [?:?]
 at com.atlassian.plugin.servlet.filter.DelegatingPluginFilter.doFilter(DelegatingPluginFilter.java:64) [atlassian-plugins-servlet-4.5.0.jar:?]
 at com.atlassian.plugin.servlet.filter.IteratingFilterChain.doFilter(IteratingFilterChain.java:37) [atlassian-plugins-servlet-4.5.0.jar:?]
 at com.atlassian.jira.tzdetect.IncludeResourcesFilter.doFilter(IncludeResourcesFilter.java:77) [?:?]
 at com.atlassian.jira.baseurl.IncludeResourcesFilter.doFilter(IncludeResourcesFilter.java:38) [?:?]
 at com.atlassian.applinks.core.rest.context.ContextFilter.doFilter(ContextFilter.java:24) [?:?]
 at com.atlassian.mywork.client.filter.ServingRequestsFilter.doFilter(ServingRequestsFilter.java:37) [?:?]
achref_bziouech
hello ,
RelatedOSWorkflowEntry is not running too . i get this logs :
 at com.atlassian.analytics.client.filter.UniversalAnalyticsFilter.doFilter(UniversalAnalyticsFilter.java:92) [?:?]
 at com.atlassian.analytics.client.filter.AbstractHttpFilter.doFilter(AbstractHttpFilter.java:39) [?:?]
Shannon S
September 28, 2017
Thank you for providing the logs. However, I will just need to see the line that starts with Caused by: to know the exact cause of the error. Can you have a look at the full Jira logs and see if you're able to find that line?
In your upgrade, did you migrate anything, or did you use the existing database and server?
Kind Regards,
Shannon
achref_bziouech
hi ,
in my upgrade i used the same server and the same database .
Caused by: org.ofbiz.core.util.GeneralRuntimeException: Error creating GenericValue (SQL Exception while getting value:  (Protocol violation: [ 14, 114, ]))
 at org.ofbiz.core.entity.EntityListIterator.next(EntityListIterator.java:274) [entityengine-1.3.4.jar:?]
 at com.atlassian.jira.ofbiz.DefaultOfBizListIterator.next(DefaultOfBizListIterator.java:100) [classes/:?]
 at com.atlassian.jira.ofbiz.WrappingOfBizListIterator.next(WrappingOfBizListIterator.java:68) [classes/:?]
 at com.atlassian.jira.appconsistency.integrity.check.AbstractEntityRelation.preview(AbstractEntityRelation.java:54) [classes/:?]
 ... 249 more
Caused by: org.ofbiz.core.entity.GenericDataSourceException: SQL Exception while getting value:  (Protocol violation: [ 14, 114, ])
 at org.ofbiz.core.entity.jdbc.SqlJdbcUtil.getValue(SqlJdbcUtil.java:700) [entityengine-1.3.4.jar:?]
 at org.ofbiz.core.entity.EntityListIterator.currentGenericValue(EntityListIterator.java:181) [entityengine-1.3.4.jar:?]
 at org.ofbiz.core.entity.EntityListIterator.next(EntityListIterator.java:267) [entityengine-1.3.4.jar:?]
 ... 252 more
Caused by: java.sql.SQLException: Protocol violation: [ 14, 114, ]
 at oracle.jdbc.driver.T4CTTIfun.receive(T4CTTIfun.java:669) [ojdbc7-12.1.0.1.jar:12.1.0.1.0]
 at oracle.jdbc.driver.T4CTTIfun.doRPC(T4CTTIfun.java:249) [ojdbc7-12.1.0.1.jar:12.1.0.1.0]
 at oracle.jdbc.driver.T4C8TTIClob.read(T4C8TTIClob.java:245) [ojdbc7-12.1.0.1.jar:12.1.0.1.0]
 at oracle.jdbc.driver.T4CConnection.getChars(T4CConnection.java:3901) [ojdbc7-12.1.0.1.jar:12.1.0.1.0]
 at oracle.sql.CLOB.getChars(CLOB.java:517) [ojdbc7-12.1.0.1.jar:12.1.0.1.0]
 at oracle.sql.CLOB.getSubString(CLOB.java:354) [ojdbc7-12.1.0.1.jar:12.1.0.1.0]
 at oracle.jdbc.driver.ClobAccessor.getString(ClobAccessor.java:454) [ojdbc7-12.1.0.1.jar:12.1.0.1.0]
 at oracle.jdbc.driver.GeneratedStatement.getString(GeneratedStatement.java:327) [ojdbc7-12.1.0.1.jar:12.1.0.1.0]
 at oracle.jdbc.driver.GeneratedScrollableResultSet.getString(GeneratedScrollableResultSet.java:882) [ojdbc7-12.1.0.1.jar:12.1.0.1.0]
 at org.apache.commons.dbcp2.DelegatingResultSet.getString(DelegatingResultSet.java:199) [commons-dbcp2-2.1.jar:2.1]
 at org.ofbiz.core.entity.jdbc.SqlJdbcUtil.getValue(SqlJdbcUtil.java:610) [entityengine-1.3.4.jar:?]
 ... 254 more
Sincerely yours ,
 Achraf Bziouech
Software Developer,  Java Apps Team
E-mail  :        abziouech@codix.tn
Mobile :        +216 53 33 84 73
Main Office : +216 71 94 04 55
Shannon S
September 28, 2017
Great, thank you! :)
Can you also confirm your current database and version?
Kind Regards,
Shannon
achref_bziouech
thank you Shannon :)
My current database info :
Application Server ContainerApache Tomcat/8.5.6
Database typeoracle10g
Database JNDI addressoracle10g jdbc:oracle:thin:@gandalf:1521:jiraprod
Database URLjdbc:oracle:thin:@gandalf:1521:jiraprod
Database versionOracle Database 11g Enterprise Edition Release 11.2.0.4.0 - 64bit Production With the Partitioning, OLAP, Data Mining and Real Application Testing options
Database driverOracle JDBC driver 12.1.0.1.0
Database collationBINARY
Shannon S
September 28, 2017
Got it. I see the issue.
The only supported version of Oracle is 12c for 7.5.0:
Can you upgrade Oracle to 12c and then let us know if you still have the issue?
Kind Regards,
Shannon
achref_bziouech
Thank you  ,
Could you please send me a link or tutorial how to upgrade Oracle version on jira to 12c?
Sincerely yours ,
 Achraf Bziouech
Shannon S
September 28, 2017
Hi Achraf,
There are two possibilities for this.
  1. You perform the upgrade using Oracle's instructions
  2. Or, you set up a new Oracle 12c database, and then migrate the data over to it.
Let us know if you have any questions!
Kind Regards,
Shannon
achref_bziouech
hello Shannon ,
Thank you so much for your help  . I will inform you  if i still have the issue.
Sincerely yours ,
 Achraf Bziouech
achref_bziouech
It works !
Thank you for your help  .
Shannon S
October 2, 2017
Great news! :) Thank you for letting me know.
Take care and have a pleasant rest of your week.
Kind Regards,
Shannon
