I'm using Jira v4.4#649-r158309
GreenHopper is v5.7.1
I've updated my Jira Import plugin to the latest version (3.5.3). Additional related plugins com.atlassian.jira.plugins.jira-workflow-designer - v.2.0.0, com.atlassian.jira.plugin.workflow.blockinglinks - v.1.0.0 , com.innovalog.jmwe.jira-misc-workflow-extensions - v.2.4.1
I want to import an existing project from Pivotal to Jira using the import plugin.
I started doing it as described in atlassin's confluence but when the import process starts I get to following error
2012-11-08 12:53:42,751 INFO - Import started by xxxxx using com.atlassian.jira.plugins.importer.imports.pivotal.PivotalDataBean 2012-11-08 12:53:42,754 INFO - ------------------------------ 2012-11-08 12:53:42,754 INFO - Importing: Users 2012-11-08 12:53:42,754 INFO - ------------------------------ 2012-11-08 12:53:42,754 INFO - Only new items will be imported 2012-11-08 12:53:44,940 INFO - 7 users associated with import. 2012-11-08 12:53:44,955 INFO - ------------------------------ 2012-11-08 12:53:44,956 INFO - Finished Importing : Users 2012-11-08 12:53:44,956 INFO - ------------------------------ 2012-11-08 12:53:44,956 INFO - 0 users successfully created. 2012-11-08 12:53:44,956 INFO - Retrieving custom fields... 2012-11-08 12:53:44,956 INFO - Retrieving projects... 2012-11-08 12:53:45,288 ERROR - Unexpected failure occurred. Importer will stop immediately. Data maybe in an unstable state java.lang.Exception: Unable to import Project ExternalProject[jiraId=<null>,id=428049,externalName=AAAAA,name=BBBBBB,key=KKK,url=<null>,lead=xxxxx.yyyyyy,description=<null>,projectCategoryName=<null>,assigneeType=3,workflowSchemeName=<null>] at com.atlassian.jira.plugins.importer.imports.importer.impl.DefaultJiraDataImporter.importProject(DefaultJiraDataImporter.java:580) at com.atlassian.jira.plugins.importer.imports.importer.impl.DefaultJiraDataImporter.doImport(DefaultJiraDataImporter.java:279) at com.atlassian.jira.plugins.importer.imports.importer.impl.ImporterCallable.call(ImporterCallable.java:25) at com.atlassian.jira.plugins.importer.imports.importer.impl.ImporterCallable.call(ImporterCallable.java:14) at com.atlassian.jira.task.TaskManagerImpl$TaskCallableDecorator.call(TaskManagerImpl.java:359) at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334) at java.util.concurrent.FutureTask.run(FutureTask.java:166) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:471) at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:334) at java.util.concurrent.FutureTask.run(FutureTask.java:166) at com.atlassian.multitenant.impl.DefaultMultiTenantManager.runForTenant(DefaultMultiTenantManager.java:61) at com.atlassian.multitenant.juc.MultiTenantExecutors$WrappedRunnable.run(MultiTenantExecutors.java:160) at com.atlassian.jira.task.ForkedThreadExecutor$ForkedRunnableDecorator.run(ForkedThreadExecutor.java:249) at java.lang.Thread.run(Thread.java:679) Caused by: java.lang.RuntimeException: Error setting up Pivotal scheme for project KKK at com.atlassian.jira.plugins.importer.imports.pivotal.PivotalDataBean.afterProjectCreated(PivotalDataBean.java:342) at com.atlassian.jira.plugins.importer.imports.importer.impl.DefaultJiraDataImporter.importProject(DefaultJiraDataImporter.java:576) ... 13 more Caused by: java.lang.RuntimeException: Error adding status IceBox at com.atlassian.jira.plugins.importer.imports.pivotal.PivotalSchemeManager.getPTStatusNameToIdMapping(PivotalSchemeManager.java:317) at com.atlassian.jira.plugins.importer.imports.pivotal.PivotalSchemeManager.loadPTWorkflow(PivotalSchemeManager.java:266) at com.atlassian.jira.plugins.importer.imports.pivotal.PivotalSchemeManager.getPTWorkflow(PivotalSchemeManager.java:261) at com.atlassian.jira.plugins.importer.imports.pivotal.PivotalSchemeManager.getPTWorkflowScheme(PivotalSchemeManager.java:238) at com.atlassian.jira.plugins.importer.imports.pivotal.PivotalSchemeManager.assignPTWorkflowScheme(PivotalSchemeManager.java:230) at com.atlassian.jira.plugins.importer.imports.pivotal.PivotalSchemeManager.setPTSchemesForProject(PivotalSchemeManager.java:167) at com.atlassian.jira.plugins.importer.imports.pivotal.PivotalDataBean.afterProjectCreated(PivotalDataBean.java:340) ... 14 more 2012-11-08 12:53:45,308 INFO - No issues need to be reindexed.
As it is a bit difficult to upgrade our jira instance quickly, i will play a bit with a CSV export from pivotal and import it. I already tried it and it imports the project with small issues.
Hi Desislav,
There is a KB for this error, please refer to the following link.
Hope it helps.
John Chin
The new project is being created but there are no PT workflow or issue type schemes created. Also this is my first Pivotal project to be imported in Jira.
Hey, you are running on a quite ancient version of JIRA Importers Plugin. I know that newer versions require JIRA 5.0+. Do you have a chance to run it on a newer version of JIRA?
Honestly it's quite possible that this bug has been fixed since then.
1) which version of GreenHopper do you use?
2) which exactly version of JIRA Importers Plugin do you use? The latest version works only with JIRA 5.0.2 and newer.
3) do you have some other plugins installed in this system?
4) do you have any additional information in JIRA log file? (<JIRA home>/logs/atlassian-jira.log)
