Error in 'Emails' tab in Jira ticket
Rupa Jain February 15, 2018
We recently made a change in Jira authentication via Crowd.  The 'username' now picks up the e-mail address of the user instead of 'firstname.lastname'.
After this change, if we use 'E-mail this Issue' button the Jira ticket, the e-mail is sent but the tab 'Emails' displays the following error:
'Error rendering 'com.metainf.jira.plugin.emailissue:audit-log-panel'. Please contact your JIRA administrators.'
Also we are getting the following error in the log:
Exception thrown while trying to call getActions() for com.metainf.jira.plugin.emailissue:audit-log-panel (The Emails Panel)
We are using the following versions:
Jira: 6.4.6
Email this Issue Plugin: 6.2.1.3
Any idea about the Jira database tables from which this plugin (Email Issue) picks up data from?
Any suggestions on how to fix this issue?
Rupa Jain February 20, 2018
This issue got fixed.
Basically there were some entries in cwd_user table that were missing in the app_user table.
The following query was used:
SELECT lower_user_name
FROM cwd_user
WHERE lower_user_name NOT IN (SELECT lower_user_name FROM app_user);
Jeff Curry
February 16, 2018
Navigating to jira-base-url/plugins/servlet/active-objects/tables/list will show you the relating database tables.
If you can provide the full stack trace from the error log I can see if there's more to be learned, Exception thrown while trying to call getActions()  is too generic
Rupa Jain February 18, 2018
Did not come across any stack trace in the log, but the following were the errors:
2018-02-16 11:08:16,579 http-bio-8080-exec-22 WARN jira.importer 668x7079x1 htjon1 147.249.171.66 /browse/ABC-4002099 [com.atlassian.ozymandias.SafePluginPointAccess] Unable to run plugin code because of 'com.atlassian.jira.util.dbc.Assertions$NullArgumentException - key should not be null!'.
2018-02-16 11:08:16,579 http-bio-8080-exec-22 ERROR jira.importer 668x7079x1 htjon1 147.249.171.66 /browse/ABC-4002099 [jira.plugin.issuetabpanel.IssueTabPanelInvokerImpl] Exception thrown while trying to call getActions() for com.metainf.jira.plugin.emailissue:audit-log-panel (The Emails Panel)
2018-02-16 11:09:10,890 http-bio-8080-exec-18 WARN jira.importer 669x7092x1 htjon1 147.249.171.66 /browse/ABC-4002099 [com.atlassian.ozymandias.SafePluginPointAccess] Unable to run plugin code because of 'com.atlassian.jira.util.dbc.Assertions$NullArgumentException - key should not be null!'.
2018-02-16 11:09:10,890 http-bio-8080-exec-18 ERROR jira.importer 669x7092x1 htjon1 147.249.171.66 /browse/ABC-4002099 [jira.plugin.issuetabpanel.IssueTabPanelInvokerImpl] Exception thrown while trying to call getActions() for com.metainf.jira.plugin.emailissue:audit-log-panel (The Emails Panel)
2018-02-16 11:09:31,954 http-bio-8080-exec-18 WARN jira.importer 669x7093x1 htjon1 147.249.171.66 /browse/ABC-4002099 [com.atlassian.ozymandias.SafePluginPointAccess] Unable to run plugin code because of 'com.atlassian.jira.util.dbc.Assertions$NullArgumentException - key should not be null!'.
2018-02-16 11:09:31,954 http-bio-8080-exec-18 ERROR jira.importer 669x7093x1 htjon1 147.249.171.66 /browse/ABC-4002099 [jira.plugin.issuetabpanel.IssueTabPanelInvokerImpl] Exception thrown while trying to call getActions() for com.metainf.jira.plugin.emailissue:audit-log-panel (The Emails Panel)
2018-02-16 11:13:15,073 http-bio-8080-exec-10 WARN rupa.goyal@fisglobal.com 673x7254x1 v3m5zh 147.249.171.66 /browse/ABC-4002098 [com.atlassian.ozymandias.SafePluginPointAccess] Unable to run plugin code because of 'com.atlassian.jira.util.dbc.Assertions$NullArgumentException - key should not be null!'.
2018-02-16 11:13:15,073 http-bio-8080-exec-10 ERROR rupa.goyal@fisglobal.com 673x7254x1 v3m5zh 147.249.171.66 /browse/ABC-4002098 [jira.plugin.issuetabpanel.IssueTabPanelInvokerImpl] Exception thrown while trying to call getActions() for com.metainf.jira.plugin.emailissue:audit-log-panel (The Emails Panel)
