×Since upgrading to Jira 5, I cannot create Issues via email - I get the following message when I do a test in the configuration:
Cannot instantiate message handler
'com.atlassian.jira.plugins.mail.handlers.CreateOrCommentHandler. This service will not work until this problem is fixed.
Any ideas? I was on Jira 4.5 before.
I've just seen this in a case from a behind the firewall customer, they:
We are looking into as to what may have caused this.
Cheers.
Thanks, the followig bug has been logged for this problem: https://jira.atlassian.com/browse/JRA-27345
This only recently stopped working though. I know external mail servers are restricted, which we're not using. I do see that "Configure services or mail handlers" is restricted, which I assume is new.
I'm seeing the same error on pre-existing and newly created handlers in my ondemand account. Did support for this handler maybe break in jira 5 ondemand?
Ondemand is a different bucket of spuds. See http://confluence.atlassian.com/display/AOD/Restricted+Functions+in+Atlassian+OnDemand
How did you update your configuration? Mail handlers have changed significantly in 5.0. If you tried to migrate then the old way will not work. Perhaps easiest is to remove and recreate mail handlers...
worksforme (standalone). Are you 'ondemand' by any chance?
Still works for me. Suggest you try a fresh install of 5.0, verify it works out of the box, then try to migrate your data...
