Error in creating a sub-task for jira 6
Priya Thevar December 9, 2013
I am getting the following error while creating a sub-ask on the create transition of a issue. Script was working fine in jira 5. After upgrading to jira 6 I get the following errors for users.
No signature of method: com.atlassian.jira.issue.managers.DefaultIssueManager.createIssueObject()
Pls help
this is the code to link the subtask
//Linking the issue with parent
Map<String,Object> newIssueParams = ["issue":newSubtask] as Map<String,Object>;
log.warn("\n\n\nnewIssueParams: ---> ${newIssueParams.dump()}\n\n\n"); //Debug the parameters
//Get the user who is currently logged in
def currentUser = jiraAuthenticationContext.getUser();
log.warn("\n\n\n******\n\n\n");
//creating the issue that links the subtask and the current User
newSubtaskGV = issueManager.createIssueObject(currentUser,newIssueParams);
log.warn("***");
//reindexing
indexManager.reIndex(newSubtaskGV);
log.warn("***");
//link the subtask with the parent issue
subTaskManager.createSubTaskIssueLink(EmpIssue, newSubtask, componentManager.getJiraAuthenticationContext().getUser());
log.warn("Subtask ${newSubtask.getKey()} is created from ${issue.getKey()}");
log.warn("You're fine till here");
log.warn("\n\n");
issueLinkManager.createIssueLink(issue.getId(),newSubtask.getId(),Long.parseLong(linkID),0,user)
ComponentManager.getInstance().getIndexManager().reIndex(newSubtask)
Script stops because of this line
log.warn("***");
RambanamP
December 15, 2013
use this to get user object
User user=ComponentAccessor.getJiraAuthenticationContext().getUser().getDirectoryUser();
Priya Thevar December 16, 2013
Thank you for the help.
What import statement has to be used for this? I am not getting the method getDirectoryUser() in IDE. It says cannot resolve symbol getDirectoryUser()
RambanamP
December 16, 2013
you have to use following dependencies in pom.xml
&lt;dependency&gt;
&lt;groupId&gt;com.atlassian.jira&lt;/groupId&gt;
&lt;artifactId&gt;jira-core&lt;/artifactId&gt;
&lt;version&gt;${jira.version}&lt;/version&gt;
&lt;scope&gt;provided&lt;/scope&gt;
&lt;/dependency&gt;
&lt;dependency&gt;
&lt;artifactId&gt;jira-api&lt;/artifactId&gt;
&lt;/dependency&gt;
Priya Thevar December 17, 2013
I got the answer to this
def public CreateSubtask(MutableIssue issue, String mySummary, User newassign)
CustomField cfemp = customFieldManager.getCustomFieldObjectByName( "Employee");
DelegatingApplicationUser cfempv = issue.getCustomFieldValue(cfemp);
User empuser = cfempv.getDirectoryUser();
CreateSubtask(issue, "Profile Creation - Resume",empuser);
This works in jira 6 without any errors of typecasting.
Bharadwaj Jannu
December 15, 2013
I don't know groovy syntax, but I just modified your code as below:
Map&lt;String,Object&gt; newIssueParams = ["issue":newSubtask] as Map&lt;String,Object&gt;;
log.warn("\n\n\nnewIssueParams: ---&gt; ${newIssueParams.dump()}\n\n\n"); //Debug the parameters
newSubtaskGV = issueManager.createIssueObject(currentUser.getName(),newIssueParams);
log.warn("***");
//reindexing
log.warn("***");
subTaskManager.createSubTaskIssueLink(EmpIssue, newSubtask, ComponentAccessor.getJiraAuthenticationContext().getUser().getDirectoryUser());
log.warn("\n\n");
issueLinkManager.createIssueLink(issue.getId(),newSubtask.getId(),Long.parseLong(linkID),0,user)// also you check which user you are giving it should be ComponentAccessor.getJiraAuthenticationContext().getUser().getDirectoryUser()
log.warn("***");
Priya Thevar December 15, 2013
I tied using it as a string. It says
No signature of method: com.onresolve.jira.groovy.postfunction.Script5.CreateSubtask() is applicable for argument types: (com.atlassian.jira.issue.IssueImpl, java.lang.String, com.atlassian.jira.user.BridgedDirectoryUser) values: [SCS-1355, Assign owner for BDM -, admin:1]
Possible solutions: CreateSubtask(com.atlassian.jira.issue.MutableIssue, java.lang.String, java.lang.String)
Bharadwaj Jannu
December 15, 2013
you just try using User as a String object rather than User object
I'm getting this error for Users
The script failed : javax.script.ScriptException: javax.script.ScriptException: org.codehaus.groovy.runtime.typehandling.GroovyCastException: Cannot cast object 'admin(admin)' with class 'com.atlassian.jira.user.DelegatingApplicationUser' to class 'com.atlassian.crowd.embedded.api.User'
I am getting this error for Users
Bharadwaj Jannu
December 10, 2013
Hello Priya,
I think you should pass a user in String type. see https://docs.atlassian.com/jira/6.0/com/atlassian/jira/issue/IssueManager.html#createIssueObject(java.lang.String, java.util.Map)
I am facing another problem in jira 6.
def public CreateSubtask(MutableIssue issue, String mySummary, User newassign )
CustomField cfemp = customFieldManager.getCustomFieldObjectByName( "Employee" );
log.warn("Employee issue assignee :" +cfempv);
CreateSubtask(issue, "Profile Creation - Resume",cfempv);
This gives the following error
java.lang.ClassCastException: com.atlassian.jira.user.DelegatingApplicationUser cannot be cast to com.atlassian.crowd.embedded.api.User
Any solution how do I pass the User parameter in CreateSubtask?
Bharadwaj Jannu
December 16, 2013
you declare User using
import com.atlassian.crowd.embedded.api.User;
John Bishop
December 9, 2013
I'm not sure what your code's issue is, but jiraAuthenticationContext.getUser(); is deprecated. You should probably change it to jiraAuthenticationContext.getLoggedInUser();.
Learn more
