Hey there,
Just trying to keep my error logs clean(ish) and have noticed that I am getting a lot of exceptions for each workflow validation that is executed. Can you tell me how I can prevent my logs from filling up with this info?
for example
{noformat}
2012-05-15 11:17:05,650 http-8080-13 ERROR nigel.rheam 677x237029x1 phhtim 10.202.36.53 /secure/CommentAssignIssue.jspa atlassian.jira.workflow.OSWorkflowManager Caught exception while attempting to perform action 1211 from workflow 50353 on issue 'LB-5430'
InvalidInputException: Error map: {customfield_12501=Complexity is required.} Error list:
at com.googlecode.jsu.util.ValidatorErrorsBuilder.process(ValidatorErrorsBuilder.java:41)
at com.googlecode.jsu.workflow.validator.GenericValidator.validate(GenericValidator.java:75)
at com.opensymphony.workflow.AbstractWorkflow.verifyInputs(AbstractWorkflow.java:1331)
at com.opensymphony.workflow.AbstractWorkflow.transitionWorkflow(AbstractWorkflow.java:1022)
at com.opensymphony.workflow.AbstractWorkflow.doAction(AbstractWorkflow.java:567)
at com.atlassian.jira.workflow.OSWorkflowManager.doWorkflowActionInsideTxn(OSWorkflowManager.java:905)
at com.atlassian.jira.workflow.OSWorkflowManager.doWorkflowAction(OSWorkflowManager.java:865)
at com.atlassian.jira.bc.issue.DefaultIssueService.transition(DefaultIssueService.java:449)
at com.atlassian.jira.web.action.issue.CommentAssignIssue.doExecute(CommentAssignIssue.java:196)
at webwork.action.ActionSupport.execute(ActionSupport.java:165)
snip...
{noformat}
and...
{noformat}
2012-05-15 11:34:21,907 http-8080-2 ERROR adam.bielasty 694x238246x1 oselx1 10.202.36.57 /secure/WorkflowUIDispatcher.jspa atlassian.jira.workflow.OSWorkflowManager Caught exception while attempting to perform action 861 from workflow 50353 on issue 'LB-5430'
InvalidInputException: Error map: {} Error list: Lead Developer is required.
at com.atlassian.jira.web.action.workflow.SimpleWorkflowAction.doExecute(SimpleWorkflowAction.java:30)
snip...
{noformat}
https://answers.atlassian.com/questions/54970/error-logs-filling-up-with-guff - Answers filling up with guff
