While uploading jira add-on i am facing an error saying reffer to logs. I have provided the log infomation.
2017-09-17 13:29:34,861 UpmAsynchronousTaskManager:thread-4 WARN vedkul617 799x1383x1 sd93kd 0:0:0:0:0:0:0:1 /rest/plugins/1.0/ [c.a.u.core.install.DefaultPluginInstallationService] Plugin installation failed: Unknown error, plugin not installed
2017-09-17 13:29:34,861 UpmAsynchronousTaskManager:thread-4 WARN vedkul617 799x1383x1 sd93kd 0:0:0:0:0:0:0:1 /rest/plugins/1.0/ [c.a.u.core.install.DefaultPluginInstallationService] com.atlassian.upm.spi.PluginInstallException: Unknown error, plugin not installed
at com.atlassian.upm.core.install.AbstractPluginInstallHandler.installArtifact(AbstractPluginInstallHandler.java:122)
at com.atlassian.upm.core.install.JarPluginInstallHandler.installPluginInternal(JarPluginInstallHandler.java:52)
at com.atlassian.upm.core.install.AbstractPluginInstallHandler.installPlugin(AbstractPluginInstallHandler.java:60)
at com.atlassian.upm.core.install.DefaultPluginInstallationService.execute(DefaultPluginInstallationService.java:117)
at com.atlassian.upm.core.install.DefaultPluginInstallationService.install(DefaultPluginInstallationService.java:91)
at com.atlassian.upm.install.UpmPluginInstallationService.install(UpmPluginInstallationService.java:97)
at com.atlassian.upm.core.rest.resources.install.InstallTask.installFromFile(InstallTask.java:156)
at com.atlassian.upm.core.rest.resources.install.InstallFromFileTask.executeTask(InstallFromFileTask.java:37)
at com.atlassian.upm.core.rest.resources.install.InstallTask.run(InstallTask.java:81)
at com.atlassian.upm.core.async.AsynchronousTaskManager.executeTask(AsynchronousTaskManager.java:124)
at com.atlassian.upm.core.async.AsynchronousTaskManager$1.call(AsynchronousTaskManager.java:102)
at com.atlassian.upm.core.async.AsynchronousTaskManager$1.call(AsynchronousTaskManager.java:99)
at com.atlassian.sal.core.executor.ThreadLocalDelegateCallable.call(ThreadLocalDelegateCallable.java:38)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
I think you have new custom field type in atlassian-plugin.xml specified multiple times. Something like...
<customfield-type key="new-cf"...
The updated logs tell you the problem - you're trying to install an add-on manually that you already have installed. "com.atlassian.plugin.PluginParseException: Found duplicate key 'new-cf' within plugin 'com.dnfcs.jira.newCFType'"
Try removing the old version rather than upgrading or installing it again.
Isn't it duplicated CF specified in atlassian-plugin.xml file?
It can be a duplicate in the xml as you say, or trying to upload version x.y.z of an add-on which is already installed at version x.y.y
hi Vedant, are there any more exceptions before this log record?
I am sharing some log information which is recorded before this log.
2017-09-18 10:03:01,352 UpmAsynchronousTaskManager:thread-3 INFO vedkul617 798x1372x1 sd93kd 0:0:0:0:0:0:0:1 /rest/plugins/1.0/installed-marketplace [c.a.plugin.loaders.ScanningPluginLoader] No plugins found to be installed
2017-09-18 10:03:01,754 UpmAsynchronousTaskManager:thread-3 ERROR vedkul617 798x1372x1 sd93kd 0:0:0:0:0:0:0:1 /rest/plugins/1.0/installed-marketplace [c.a.plugin.loaders.ScanningPluginLoader] Unable to deploy plugin 'com.dnfcs.jira.newCFType' from 'Unit: C:\Program Files\Atlassian\Application Data\JIRA\plugins\installed-plugins\plugin_124607812975894791_newCFType-1.0.jar (1505709181215)'.
2017-09-18 10:03:01,754 UpmAsynchronousTaskManager:thread-3 ERROR vedkul617 798x1372x1 sd93kd 0:0:0:0:0:0:0:1 /rest/plugins/1.0/installed-marketplace [c.a.plugin.loaders.ScanningPluginLoader] Because of the following exception:
at com.atlassian.plugin.parsers.XmlDescriptorParser.configurePlugin(XmlDescriptorParser.java:149)
at com.atlassian.plugin.osgi.factory.OsgiPluginFactory.create(OsgiPluginFactory.java:240)
at com.atlassian.jira.plugin.MasterPluginFactory.create(MasterPluginFactory.java:73)
at com.atlassian.plugin.loaders.ScanningPluginLoader.deployPluginFromUnit(ScanningPluginLoader.java:142)
at com.atlassian.plugin.loaders.ScanningPluginLoader.loadFoundPlugins(ScanningPluginLoader.java:111)
at com.atlassian.plugin.loaders.PermissionCheckingPluginLoader.loadFoundPlugins(PermissionCheckingPluginLoader.java:33)
at com.atlassian.plugin.manager.DefaultPluginManager.scanForNewPlugins(DefaultPluginManager.java:887)
at com.atlassian.plugin.manager.DefaultPluginManager.installPlugins(DefaultPluginManager.java:845)
at com.atlassian.jira.plugin.JiraPluginManager.installPlugins(JiraPluginManager.java:171)
... 2 filtered
at java.lang.reflect.Method.invoke(Method.java:498)
at com.atlassian.plugin.util.ContextClassLoaderSettingInvocationHandler.invoke(ContextClassLoaderSettingInvocationHandler.java:26)
at com.sun.proxy.$Proxy375.installPlugins(Unknown Source)
... 2 filtered
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:302)
at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.doInvoke(ServiceInvoker.java:56)
at org.eclipse.gemini.blueprint.service.importer.support.internal.aop.ServiceInvoker.invoke(ServiceInvoker.java:60)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179)
at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:133)
at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:121)
at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invokeUnprivileged(ServiceTCCLInterceptor.java:70)
at org.eclipse.gemini.blueprint.service.util.internal.aop.ServiceTCCLInterceptor.invoke(ServiceTCCLInterceptor.java:53)
at org.eclipse.gemini.blueprint.service.importer.support.LocalBundleContextAdvice.invoke(LocalBundleContextAdvice.java:57)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:208)
at com.sun.proxy.$Proxy3388.installPlugins(Unknown Source)
at com.atlassian.upm.core.install.AbstractPluginInstallHandler$1.doInTransaction(AbstractPluginInstallHandler.java:139)
at com.atlassian.upm.core.install.AbstractPluginInstallHandler$1.doInTransaction(AbstractPluginInstallHandler.java:134)
at com.atlassian.sal.core.transaction.HostContextTransactionTemplate$1.doInTransaction(HostContextTransactionTemplate.java:21)
at com.atlassian.jira.DefaultHostContextAccessor.doInTransaction(DefaultHostContextAccessor.java:34)
... 2 filtered
at com.sun.proxy.$Proxy37.doInTransaction(Unknown Source)
... 2 filtered
at com.atlassian.plugin.osgi.bridge.external.HostComponentFactoryBean$DynamicServiceInvocationHandler.invoke(HostComponentFactoryBean.java:136)
at com.atlassian.sal.core.transaction.HostContextTransactionTemplate.execute(HostContextTransactionTemplate.java:18)
... 2 filtered
at com.sun.proxy.$Proxy3396.execute(Unknown Source)
at com.atlassian.upm.core.install.AbstractPluginInstallHandler.installArtifacts(AbstractPluginInstallHandler.java:133)
at com.atlassian.upm.core.install.AbstractPluginInstallHandler.installArtifact(AbstractPluginInstallHandler.java:119)
2017-09-18 10:03:01,893 UpmAsynchronousTaskManager:thread-3 WARN vedkul617 798x1372x1 sd93kd 0:0:0:0:0:0:0:1 /rest/plugins/1.0/installed-marketplace [c.a.u.core.install.DefaultPluginInstallationService] Plugin installation failed: Unknown error, plugin not installed
2017-09-18 10:03:01,893 UpmAsynchronousTaskManager:thread-3 WARN vedkul617 798x1372x1 sd93kd 0:0:0:0:0:0:0:1 /rest/plugins/1.0/installed-marketplace [c.a.u.core.install.DefaultPluginInstallationService] com.atlassian.upm.spi.PluginInstallException: Unknown error, plugin not installed
Before this log record, these are some logs I found.
... 2 filtered
... 2 filtered
... 2 filtered
... 2 filtered
... 2 filtered
... 2 filtered
... 2 filtered
... 2 filtered
... 2 filtered
... 2 filtered
I received notification about change on this question but log record is the same, did you change anyting?
The emails on Lithium are very poor, with random duplicates being sent, and often the mail (original and duplicates) suffer several hours of delays.
I replied the first time but it was not showing my message so I tried two more times.
