Error on select data for custom picker field
Harald Hiebl
October 25, 2025
I have configured a csutom picker field for data from ServiceNow, but on loading options I get following error:
Error searching: java.lang.UnsupportedOperationException
at org.codehaus.groovy.runtime.ConvertedMap.invokeCustom(ConvertedMap.java:52) at org.codehaus.groovy.runtime.ConversionHandler.invoke(ConversionHandler.java:113) at jdk.proxy1/jdk.proxy1.$Proxy5118.isEmpty(Unknown Source)
My code for the field is:
HTTPBuilder getHttpBuilder() {
    new HTTPBuilder("https://xxx.com"
search = {
    HttpBuilder.request(Method.GET, ContentType.JSON) {
        headers.Accecpt = 'application/json'
        headers."x-sn-apikey" =  "<TOKEN>"
        uri.path = "/api/now/v2/table/cmdb_ci_service_business"
        uri.query = [fields: 'sys_id, name']
toOption = { Map<String, String> map, Closure<String> highlight ->
    new PickerOption(
        value: map.sys_id,
        label: map.name,
        html: highlight(map.sys_id, false)
Any idea, why the json object can not be converted to a map?
If I create a separate output for the http request, all data are available:
def output = HttpBuilder.request(Method.GET, ContentType.JSON) {
    response.failure = { null }
def bsNumber = output["result"]*."number"
def bsName = output["result"]*."name"
def bsSys = output["result"]*."sys_id"
log.info(bsNumber)
log.info(bsName)
log.info(bsSys)
SERVER
