×Dear ALL,
I have created an automation rule for editing (PUT) in a specifc confluence page the value of a field (called in my case "% Completion").
But you get an error message saying:
Error publishing webhook. Response HTTP status: 401
Do you see a reason for that?
Find please attached my rule.
Thanks in advance, Vincenzo.
401 means permission issue, you are not authenticate. Are you sure to provide the right Authentication param ?
Regards
thanks for your reply.
No, I'm not sure: how can I authenticate myself? I don't know that.
Thanks, Vincenzo.
Hi
I will use a service account if you can instead of your own, as it's this user that will be use for the action.
Also I would save the token as secret first then use the secret.
How to create the basic authen token
Regards
