I installed Jira successfully and started the first wizard. after defining database (Local SQL Server) it gets error and redirects me to
[HostURL}/secure/errors.jsp
I see some tables are created in SQL Server Database. but can't open jira on browser. I removed Jira Home Directory and restarted the service. It got the same error exactly after I fill DB information.
Here is the log file:
Database configuration OK
___ Database Configuration ________________
Loading entityengine.xml from : file:/C:/Program%20Files/Atlassian/JIRA/atlassian-jira/WEB-INF/classes/entityengine.xml
Entity model field type name : mssql
Entity model schema name : dbo
Database Version : Microsoft SQL Server - 13.00.1601
Database Driver : Microsoft JDBC Driver 6.2 for SQL Server - 6.2.1.0
Database URL : jdbc:sqlserver://localhost:1433;jaasConfigurationName=SQLJDBCDriver;serverPreparedStatementDiscardThreshold=10;enablePrepareOnFirstPreparedStatementCall=false;fips=false;socketTimeout=0;authentication=NotSpecified;authenticationScheme=nativeAuthentication;xopenStates=false;sendTimeAsDatetime=true;trustStoreType=JKS;trustServerCertificate=false;TransparentNetworkIPResolution=true;serverNameAsACE=false;sendStringParametersAsUnicode=true;selectMethod=direct;responseBuffering=adaptive;queryTimeout=-1;packetSize=8000;multiSubnetFailover=false;loginTimeout=15;lockTimeout=-1;lastUpdateCount=true;encrypt=false;disableStatementPooling=true;databaseName=Jira;columnEncryptionSetting=Disabled;applicationName=Microsoft JDBC Driver for SQL Server;applicationIntent=readwrite;
Database JDBC config : mssql jdbc:sqlserver://;serverName=localhost;portNumber=1433;databaseName=Jira
2018-08-12 15:40:14,452 http-nio-8085-exec-23 ERROR anonymous 940x10x1 fvsr82 0:0:0:0:0:0:0:1 /secure/SetupDatabase.jspa [c.a.jira.appconsistency.JiraSetupConfig] Unable to load values for CacheKey[entityName=jira.properties,entityId=1]
com.opensymphony.module.propertyset.PropertyImplementationException: Unable to load values for CacheKey[entityName=jira.properties,entityId=1]
at com.atlassian.jira.propertyset.CachingOfBizPropertyEntryStore.propEx(CachingOfBizPropertyEntryStore.java:332)
at com.atlassian.jira.propertyset.CachingOfBizPropertyEntryStore.resolve(CachingOfBizPropertyEntryStore.java:105)
at com.atlassian.jira.propertyset.CachingOfBizPropertyEntryStore.getEntry(CachingOfBizPropertyEntryStore.java:123)
at com.atlassian.jira.propertyset.CachingOfBizPropertySet.get(CachingOfBizPropertySet.java:189)
at com.opensymphony.module.propertyset.AbstractPropertySet.getString(AbstractPropertySet.java:305)
at com.atlassian.jira.config.properties.ApplicationPropertiesStore.getStringFromDb(ApplicationPropertiesStore.java:234)
at com.atlassian.jira.config.properties.ApplicationPropertiesImpl.getString(ApplicationPropertiesImpl.java:54)
at com.atlassian.jira.appconsistency.JiraSetupConfig.isSetup(JiraSetupConfig.java:29)
at com.atlassian.jira.instance.InstanceStateProvider.isInstalling(InstanceStateProvider.java:88)
at com.atlassian.jira.instance.InstanceStateProvider.currentState(InstanceStateProvider.java:64)
at com.atlassian.jira.startup.mode.DefaultStartupModeReference.determineStartupMode(DefaultStartupModeReference.java:33)
at com.atlassian.jira.startup.mode.DefaultStartupModeReference.initialise(DefaultStartupModeReference.java:26)
at com.atlassian.jira.startup.DefaultJiraLauncher.recordStartupMode(DefaultJiraLauncher.java:153)
at com.atlassian.jira.startup.DefaultJiraLauncher.lambda$postDbLaunch$2(DefaultJiraLauncher.java:140)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.runPostDbSetupRunnables(DatabaseConfigurationManagerImpl.java:286)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.activateDatabase(DatabaseConfigurationManagerImpl.java:279)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.activateDatabase(DatabaseConfigurationManagerImpl.java:243)
at com.atlassian.jira.web.action.setup.SetupDatabase.doExecute(SetupDatabase.java:207)
... 1 filtered
at com.atlassian.jira.action.JiraActionSupport.execute(JiraActionSupport.java:63)
... 7 filtered
at javax.servlet.http.HttpServlet.service(HttpServlet.java:742)
... 45 filtered
at com.atlassian.jira.security.JiraSecurityFilter.lambda$doFilter$0(JiraSecurityFilter.java:66)
... 1 filtered
at com.atlassian.jira.security.JiraSecurityFilter.doFilter(JiraSecurityFilter.java:64)
... 31 filtered
at com.atlassian.jira.servermetrics.CorrelationIdPopulatorFilter.doFilter(CorrelationIdPopulatorFilter.java:30)
... 24 filtered
at com.atlassian.jira.servermetrics.MetricsCollectorFilter.doFilter(MetricsCollectorFilter.java:25)
... 24 filtered
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Unknown Source)
Caused by: com.atlassian.cache.CacheException: com.querydsl.core.QueryException: Caught SQLServerException for select O_S_PROPERTY_ENTRY.property_key, O_S_PROPERTY_ENTRY.propertytype
from dbo.propertyentry O_S_PROPERTY_ENTRY
where O_S_PROPERTY_ENTRY.entity_name = ? and O_S_PROPERTY_ENTRY.entity_id = ?
order by O_S_PROPERTY_ENTRY.id desc
at com.atlassian.cache.memory.DelegatingCache.get(DelegatingCache.java:211)
at com.atlassian.cache.memory.DelegatingCache.get(DelegatingCache.java:162)
... 159 more
Caused by: com.querydsl.core.QueryException: Caught SQLServerException for select O_S_PROPERTY_ENTRY.property_key, O_S_PROPERTY_ENTRY.propertytype
at com.querydsl.sql.DefaultSQLExceptionTranslator.translate(DefaultSQLExceptionTranslator.java:50)
at com.querydsl.sql.Configuration.translate(Configuration.java:459)
at com.atlassian.jira.propertyset.CachingOfBizPropertyEntryStore$PropertySetData.lambda$loadPropertyKeysAndTypes$2(CachingOfBizPropertyEntryStore.java:472)
at com.atlassian.jira.database.DefaultQueryDslAccessor$1.lambda$executeQuery$0(DefaultQueryDslAccessor.java:85)
at com.atlassian.jira.database.DatabaseAccessorImpl.executeQuery(DatabaseAccessorImpl.java:68)
at com.atlassian.jira.database.DefaultQueryDslAccessor$1.executeQuery(DefaultQueryDslAccessor.java:84)
at com.atlassian.jira.propertyset.CachingOfBizPropertyEntryStore.query(CachingOfBizPropertyEntryStore.java:284)
at com.atlassian.jira.propertyset.CachingOfBizPropertyEntryStore.access$200(CachingOfBizPropertyEntryStore.java:64)
at com.atlassian.jira.propertyset.CachingOfBizPropertyEntryStore$PropertySetData.loadPropertyKeysAndTypes(CachingOfBizPropertyEntryStore.java:466)
at com.atlassian.jira.propertyset.CachingOfBizPropertyEntryStore$PropertySetData.<init>(CachingOfBizPropertyEntryStore.java:426)
at com.atlassian.jira.propertyset.CachingOfBizPropertyEntryStore.loadPropertySetData(CachingOfBizPropertyEntryStore.java:270)
at com.atlassian.cache.memory.MemoryCacheManager$3$1.load(MemoryCacheManager.java:207)
at com.google.common.cache.LocalCache$LocalManualCache.get(LocalCache.java:4739)
at com.atlassian.cache.memory.DelegatingCache.get(DelegatingCache.java:177)
... 161 more
Caused by: com.microsoft.sqlserver.jdbc.SQLServerException: Invalid column name 'entity_name'.
at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDatabaseError(SQLServerException.java:258)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.getNextResult(SQLServerStatement.java:1535)
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.doExecutePreparedStatement(SQLServerPreparedStatement.java:467)
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement$PrepStmtExecCmd.doExecute(SQLServerPreparedStatement.java:409)
at com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:7151)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeCommand(SQLServerStatement.java:219)
at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeStatement(SQLServerStatement.java:199)
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.executeQuery(SQLServerPreparedStatement.java:331)
at org.apache.commons.dbcp2.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:83)
at com.querydsl.sql.AbstractSQLQuery.fetch(AbstractSQLQuery.java:446)
... 181 more
2018-08-12 15:40:14,471 http-nio-8085-exec-23 ERROR [o.a.c.c.C.[.[localhost].[/].[action]] Servlet.service() for servlet [action] in context with path [] threw exception [com.opensymphony.module.propertyset.PropertyImplementationException: Unable to load values for CacheKey[entityName=jira.properties,entityId=1]] with root cause
at com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(SQLServerConnection.java:2478)
... 1 filtered
... 7 filtered
... 45 filtered
... 1 filtered
... 31 filtered
... 24 filtered
... 24 filtered
2018-08-12 15:40:14,481 http-nio-8085-exec-23 ERROR [c.atlassian.instrumentation.Instrument] Unable to snapshot thread local operations (implementation of OpTimerFactory is not a ThreadLocalOpTimerFactory): null
2018-08-12 15:40:14,542 http-nio-8085-exec-23 ERROR [c.a.j.web.servlet.InternalServerErrorServlet] {errorId=20372fcd-c8a7-4095-b972-24370d30bbdd, interpretedMsg=, cause=com.opensymphony.module.propertyset.PropertyImplementationException: Unable to load values for CacheKey[entityName=jira.properties,entityId=1], stacktrace=com.opensymphony.module.propertyset.PropertyImplementationException: Unable to load values for CacheKey[entityName=jira.properties,entityId=1]
at com.atlassian.jira.propertyset.CachingOfBizPropertyEntryStore.propEx(CachingOfBizPropertyEntryStore.java:332) [classes/:?]
at com.atlassian.jira.propertyset.CachingOfBizPropertyEntryStore.resolve(CachingOfBizPropertyEntryStore.java:105) [classes/:?]
at com.atlassian.jira.propertyset.CachingOfBizPropertyEntryStore.getType(CachingOfBizPropertyEntryStore.java:133) [classes/:?]
at com.atlassian.jira.propertyset.CachingOfBizPropertySet.exists(CachingOfBizPropertySet.java:139) [classes/:?]
at com.atlassian.jira.config.properties.ApplicationPropertiesStore.getOption(ApplicationPropertiesStore.java:158) [classes/:?]
at com.atlassian.jira.config.properties.ApplicationPropertiesImpl.getOption(ApplicationPropertiesImpl.java:88) [classes/:?]
at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49) [tomcat-coyote.jar:8.5.29]
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [?:1.8.0_181]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [?:1.8.0_181]
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61) [tomcat-util.jar:8.5.29]
at java.lang.Thread.run(Unknown Source) [?:1.8.0_181]
at com.atlassian.cache.memory.DelegatingCache.get(DelegatingCache.java:211) [atlassian-cache-memory-3.2.0.jar:?]
at com.atlassian.cache.memory.DelegatingCache.get(DelegatingCache.java:162) [atlassian-cache-memory-3.2.0.jar:?]
at com.atlassian.jira.propertyset.CachingOfBizPropertyEntryStore.resolve(CachingOfBizPropertyEntryStore.java:103) [classes/:?]
... 154 more
at com.querydsl.sql.DefaultSQLExceptionTranslator.translate(DefaultSQLExceptionTranslator.java:50) [querydsl-sql-4.1.4.jar:?]
at com.querydsl.sql.Configuration.translate(Configuration.java:459) [querydsl-sql-4.1.4.jar:?]
at com.querydsl.sql.AbstractSQLQuery.fetch(AbstractSQLQuery.java:502) [querydsl-sql-4.1.4.jar:?]
at com.atlassian.jira.propertyset.CachingOfBizPropertyEntryStore$PropertySetData.lambda$loadPropertyKeysAndTypes$2(CachingOfBizPropertyEntryStore.java:472) [classes/:?]
at com.atlassian.jira.database.DefaultQueryDslAccessor$1.lambda$executeQuery$0(DefaultQueryDslAccessor.java:85) [classes/:?]
at com.atlassian.jira.database.DatabaseAccessorImpl.executeQuery(DatabaseAccessorImpl.java:68) [classes/:?]
at com.atlassian.jira.database.DefaultQueryDslAccessor$1.executeQuery(DefaultQueryDslAccessor.java:84) [classes/:?]
at com.google.common.cache.LocalCache$Segment.lockedGetOrLoad(LocalCache.java:2282) [closure-compiler-v20151216.jar:?]
at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2197) [closure-compiler-v20151216.jar:?]
at com.google.common.cache.LocalCache.get(LocalCache.java:3937) [closure-compiler-v20151216.jar:?]
at com.google.common.cache.LocalCache$LocalManualCache.get(LocalCache.java:4739) [closure-compiler-v20151216.jar:?]
at com.atlassian.cache.memory.DelegatingCache.get(DelegatingCache.java:177) [atlassian-cache-memory-3.2.0.jar:?]
... 156 more
at com.microsoft.sqlserver.jdbc.SQLServerException.makeFromDatabaseError(SQLServerException.java:258) [mssql-jdbc-6.2.1.jre8.jar:?]
at com.microsoft.sqlserver.jdbc.SQLServerStatement.getNextResult(SQLServerStatement.java:1535) [mssql-jdbc-6.2.1.jre8.jar:?]
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.doExecutePreparedStatement(SQLServerPreparedStatement.java:467) [mssql-jdbc-6.2.1.jre8.jar:?]
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement$PrepStmtExecCmd.doExecute(SQLServerPreparedStatement.java:409) [mssql-jdbc-6.2.1.jre8.jar:?]
at com.microsoft.sqlserver.jdbc.TDSCommand.execute(IOBuffer.java:7151) [mssql-jdbc-6.2.1.jre8.jar:?]
at com.microsoft.sqlserver.jdbc.SQLServerConnection.executeCommand(SQLServerConnection.java:2478) [mssql-jdbc-6.2.1.jre8.jar:?]
at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeCommand(SQLServerStatement.java:219) [mssql-jdbc-6.2.1.jre8.jar:?]
at com.microsoft.sqlserver.jdbc.SQLServerStatement.executeStatement(SQLServerStatement.java:199) [mssql-jdbc-6.2.1.jre8.jar:?]
at com.microsoft.sqlserver.jdbc.SQLServerPreparedStatement.executeQuery(SQLServerPreparedStatement.java:331) [mssql-jdbc-6.2.1.jre8.jar:?]
at org.apache.commons.dbcp2.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:83) [commons-dbcp2-2.1.jar:2.1]
at com.querydsl.sql.AbstractSQLQuery.fetch(AbstractSQLQuery.java:446) [querydsl-sql-4.1.4.jar:?]
... 176 more
, referer=http://localhost:8085/secure/SetupDatabase.jspa, servletErrorMessage=}
2018-08-12 15:44:42,754 http-nio-8085-exec-4 WARN anonymous 944x12x1 fvsr82 0:0:0:0:0:0:0:1 /secure/errors.jsp [c.a.jira.security.JiraSecurityFilter] Rejecting security-sensitive request that bypassed Johnson filter: /secure/errors.jsp
How can I fix the error?
Hello @Ahmad Behzadi,
based on this thread with the same error encountered, it might have to do with user permissions.
Are you sure your SQL user has enough permissions ? It needs the following:
Give this user full create, read and write permissions for the database tables. Confluence must be able to create its own schema. Refer to the SQL Server documentation for how to do this.
Let me know if this helps,
—Alexis
