Error when trying to Enable JMC for project
Deleted user November 14, 2012
When trying to Enable JMC for project I got the error
"Project with ID: 11020 not found"
There is no such o project (11020) in our system. The problem is only for the project I used with JMC before with previous JIRA version. After JIRA upgrade to 5.1.7 it stoped working and I cannot enable it.
All the other projects (where I have never used JMC before) works fine with JMC (I can enable it).
Ps. I use JIRA 5.1.7 and already tried to disable/enable plugin, and even restarted JIRA - does not work.
Could you help?
Deleted user January 1, 2013
Any idea how to solve this? Reinstalling JMC didn't help.
Deleted user January 6, 2013
Solved! The problem was with access rights. Even though I had admin rights to click 'Enable' 'Disable' JMC it was not enough and it caused an error for some of the projects. When our IT admin, who has highest access rights tried the same it workd.
Afeter giving me some more admin rights it worked also for me!
