Error while restoring backup
Ed Sattar December 9, 2013
I am facing following issue while restoring backup on my QA machine.
Unexpected error occurred during import: org.ofbiz.core.entity.GenericEntityException: while inserting: [GenericEntity:UserHistoryItem][id,13602][username,rjstafford][entityId,10000][lastViewed,1377550213207][type,Dashboard] (SQL Exception while executing the following:INSERT INTO userhistoryitem (ID, entitytype, entityid, USERNAME, lastviewed, data) VALUES (?, ?, ?, ?, ?, ?) (Deadlock found when trying to get lock; try restarting transaction))
it is UTF-8 . Anyhow after trying again and again it worked.
Theinvisibleman
December 9, 2013
Could you check and confirm if the database that you are using for your JIRA instance is using utf-8 encoding? If it's not, please create a new database with utf-8 encoding and then try restoring the backup there.
