Error while serializing using jackson
Shivprasad Dhakane
While develoing server addon, I am getting exception,
org.codehaus.jackson.map.JsonMappingException: No serializer found for class com.apps.vo.ValidationResult and no properties discovered to create BeanSerializer (to avoid exception, disable SerializationConfig.Feature.FAIL_ON_EMPTY_BEANS)
[INFO] [talledLocalContainer] org.codehaus.jackson.map.JsonMappingException: No serializer found for class com.apps.vo.ValidationResult and no properties discovered to create BeanSerializer (to avoid exception, disable SerializationConfig.Feature.FAIL_ON_EMPTY_BEANS) )
[INFO] [talledLocalContainer] at org.codehaus.jackson.map.ser.impl.UnknownSerializer.failForEmpty(UnknownSerializer.java:52)
[INFO] [talledLocalContainer] at org.codehaus.jackson.map.ser.impl.UnknownSerializer.serialize(UnknownSerializer.java:25)
[INFO] [talledLocalContainer] at org.codehaus.jackson.map.ser.StdSerializerProvider._serializeValue(StdSerializerProvider.java:610)
[INFO] [talledLocalContainer] at org.codehaus.jackson.map.ser.StdSerializerProvider.serializeValue(StdSerializerProvider.java:256)
[INFO] [talledLocalContainer] at org.codehaus.jackson.map.ObjectMapper.writeValue(ObjectMapper.java:1613)
[INFO] [talledLocalContainer] at org.codehaus.jackson.jaxrs.JacksonJsonProvider.writeTo(JacksonJsonProvider.java:559)
[INFO] [talledLocalContainer] at com.sun.jersey.spi.container.ContainerResponse.write(ContainerResponse.java:302)
Below is my pom.xml
<properties>
<project.build.sourceEncoding>UTF-8</project.build.sourceEncoding>
<atlassian.spring.scanner.version>1.2.13</atlassian.spring.scanner.version>
<spring.version>4.3.8.RELEASE</spring.version>
<jersey.version>2.25.1</jersey.version>
<maven.compiler.source>1.8</maven.compiler.source>
<maven.compiler.target>1.8</maven.compiler.target>
</properties>
<dependencies>
<dependency>
<groupId>javax.inject</groupId>
<artifactId>javax.inject</artifactId>
<version>1</version>
<scope>provided</scope>
</dependency>
<dependency>
<groupId>javax.xml.bind</groupId>
<artifactId>jaxb-api</artifactId>
<version>2.2.12</version>
</dependency>
<dependency>
<groupId>javax.servlet</groupId>
<artifactId>javax.servlet-api</artifactId>
<version>3.1.0</version>
</dependency>
<!-- JSON support -->
<dependency>
<groupId>com.google.code.gson</groupId>
<artifactId>gson</artifactId>
<version>2.3.1</version>
</dependency>
<dependency>
<groupId>com.google.guava</groupId>
<artifactId>guava</artifactId>
<version>18.0</version>
</dependency>
<!-- https://mvnrepository.com/artifact/org.apache.commons/commons-lang3 -->
<dependency>
<groupId>org.apache.commons</groupId>
<artifactId>commons-lang3</artifactId>
<version>3.6</version>
</dependency>
<!-- https://mvnrepository.com/artifact/org.apache.commons/commons-text -->
<dependency>
<artifactId>commons-text</artifactId>
<version>1.1</version>
</dependency>
<dependency>
<groupId>junit</groupId>
<artifactId>junit</artifactId>
<version>4.12</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>org.springframework</groupId>
<artifactId>spring-test</artifactId>
<version>${spring.version}</version>
<scope>test</scope>
</dependency>
<!-- https://mvnrepository.com/artifact/org.mockito/mockito-all -->
<dependency>
<groupId>org.mockito</groupId>
<artifactId>mockito-all</artifactId>
<version>1.9.5</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>org.glassfish.jersey.test-framework.providers</groupId>
<artifactId>jersey-test-framework-provider-grizzly2</artifactId>
<version>${jersey.version}</version>
<scope>test</scope>
</dependency>
<dependency>
<groupId>javax.ws.rs</groupId>
<artifactId>javax.ws.rs-api</artifactId>
<version>2.1</version>
</dependency>
<dependency>
<artifactId>spring-context-support</artifactId>
</dependency>
<dependency>
<groupId>com.samskivert</groupId>
<artifactId>jmustache</artifactId>
<version>1.14</version>
</dependency>
<dependency>
<artifactId>spring-tx</artifactId>
</dependency>
<!-- https://mvnrepository.com/artifact/org.springframework.data/spring-data-commons-core -->
<dependency>
<groupId>org.springframework.data</groupId>
<artifactId>spring-data-commons</artifactId>
<version>1.13.3.RELEASE</version>
</dependency>
<dependency>
<groupId>javax.validation</groupId>
<artifactId>validation-api</artifactId>
<version>2.0.0.Final</version>
</dependency>
<dependency>
<groupId>org.quartz-scheduler</groupId>
<artifactId>quartz</artifactId>
<version>2.2.3</version>
</dependency>
<dependency>
<artifactId>quartz-jobs</artifactId>
</dependency>
<!-- https://mvnrepository.com/artifact/com.fasterxml.jackson.core/jackson-databind -->
<dependency>
<groupId>com.fasterxml.jackson.core</groupId>
<artifactId>jackson-databind</artifactId>
<version>2.8.8</version>
</dependency>
<dependency>
<groupId>org.slf4j</groupId>
<artifactId>slf4j-api</artifactId>
<version>1.6.6</version>
</dependency>
</dependencies>
this is an independent project , which will be included in server addon.
How can i solve this?
Register now
