Excel Query not loading all columns/fields
Hans Meijer
I have created a filter with the columns needed. One of the columns is "Linked Issues". I believe this is a standard field in JIRA.
In excel, i am setting up query connection from web to this filter:
https://<jira-server>/sr/jira.issueviews:searchrequest-csv-current-fields/<filter number>/SearchRequest-<filter-number>.csv
All seems fine, but does not load the specific "Linked Issues" field values.
What is going wrong? Or what can i do to import this info into excel quary?
Looking forward to any support.
Thanks in advance, and regards,
Hans
Aron Gombas _Midori_
We developed an Excel exporter app and found that there are several standard and custom field implementations in Jira that don't work well when exporting to CSV and when exporting in general. We found that some field classes have missing or partial implementation of the corresponding Java methods. (And therefore it is not likely that you can bypass the problem.)
Eventually, you may want to try Better Excel Exporter for your use case.
(Disclaimer: this is the paid app we developed.)
