Exception when making transition (condition on non-linked issues)
Sergio July 15, 2013
This is my configuration:
My parent links are the following:
And the problem is that when I try to make the transition (I'm on TW-9), I get this exception:
An unknown exception occured executing Validator com.fca.jira.plugins.workflowToolbox.AnyIssueValidator@7dfdf768: root cause: java.lang.StringBuffer cannot be cast to java.lang.String
I have had a look to the logs, but I don't find anything explanatory.
Any idea?
Thanks.
Sergio
Fidel Castro
June 6, 2014
Hi Sergio,
Sorry for such a so late answer, but I have just discovered your question. In current version of the plugin (2.1.19), that validator has been renamed to "Validation on a list of issue keys", and this problem should have been solved.
To notify any issue or question about JIRA Workflow Toolbox, you can also create an issue at support site.
Fidel
Register here ⬇️
